Salta al contenuto principale
Kodak S100 EF Flash Replacement
Cosa ti serve
  1. Kodak S100 EF Flash Replacement, Front Cover: passo 1, immagine 1 di 1
    • Have the camera facing upwards and the flash closest to you.
    • Unscrew the two 6.2 mm Phillips screws on the top half of the camera.
  2. Kodak S100 EF Flash Replacement: passo 2, immagine 1 di 1
    • Flip the camera over to the other side-with flash farthest from you.
    • Unscrew top two 6.2mm Phillips screws on this side.
  3. Kodak S100 EF Flash Replacement: passo 3, immagine 1 di 1
    • Turn the camera so the bottom is facing up with the front-facing away.
    • Unscrew the 6.2mm Phillips screw on the top right.
    • The front cover is now unscrewed and should be lifted evenly and removed.
  4. Kodak S100 EF Flash Replacement, Flash: passo 4, immagine 1 di 1
Conclusione
Nick
Membro da: 04/26/11
4 Reputazione
1 Guida realizzata
Cal Poly, Team 25-28, Garner Spring 2011 Membro di Cal Poly, Team 25-28, Garner Spring 2011
CPSU-GARNER-S11S25G28
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 19
Tutti i Tempi: 2,613
