Salta al contenuto principale
Kodak S100 EF Film Replacement
Cosa ti serve
  1. Kodak S100 EF Film Replacement, Film: passo 1, immagine 1 di 1
    • Lift up the lever from the center of the film roller.
    • Turn it clockwise to roll up the film until you feel the roller release, indicating all the film has been rolled up.
  2. Kodak S100 EF Film Replacement: passo 2, immagine 1 di 1
    • On the far left side on the back of the camera there is a switch that says "open."
    • Slide the button up to the top where it says "open."
    • This should pop open the door, revealing the rolled up film inside.
  3. Kodak S100 EF Film Replacement: passo 3, immagine 1 di 1
    • To take out the old film and insert the new, you must lift up on the film roller.
    • Pull up on the lever to pop the roller up which will release the film.
    • Remove the old roll of film and slide in the new roll.
    • Push the roller back down to secure the film.
  4. Kodak S100 EF Film Replacement: passo 4, immagine 1 di 1
    • To prepare the film for use, slightly pull the tail of the film out of the roll.
    • Drag the tail end of the film past the rotating column on the right side.
    • Attach the hooks at the base of the column to the holes located at the bottom of the film.
  5. Kodak S100 EF Film Replacement: passo 5, immagine 1 di 1
    • After the film is secured, close the camera door.
    • Make sure the lever is put back in place on the film roller.
    • Use the scroll wheel to advance the film until it is ready to take pictures.
Conclusione
Once the film is in place-to reassemble the camera-close the camera door and make sure the scroll wheel is pushed back down.
Michelle
Membro da: 04/04/11
107 Reputazione
5 Guide realizzate
Cal Poly, Team 25-28, Garner Spring 2011 Membro di Cal Poly, Team 25-28, Garner Spring 2011
CPSU-GARNER-S11S25G28
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 35
Tutti i Tempi: 9,080
