Salta al contenuto principale
Kodak PixPro AZ251 Shutter Button Replacement
Cosa ti serve
  1. Kodak PixPro AZ251 Shutter Button Replacement, Batteries: passo 1, immagine 1 di 2 Kodak PixPro AZ251 Shutter Button Replacement, Batteries: passo 1, immagine 2 di 2
    • Slide switch to open lock position.
  2. Kodak PixPro AZ251 Shutter Button Replacement: passo 2, immagine 1 di 2 Kodak PixPro AZ251 Shutter Button Replacement: passo 2, immagine 2 di 2
    • Press down on the battery cover and slide outwards to open.
  3. Kodak PixPro AZ251 Shutter Button Replacement: passo 3, immagine 1 di 1
    • Remove the batteries.
  4. Kodak PixPro AZ251 Shutter Button Replacement, Back Cover: passo 4, immagine 1 di 3 Kodak PixPro AZ251 Shutter Button Replacement, Back Cover: passo 4, immagine 2 di 3 Kodak PixPro AZ251 Shutter Button Replacement, Back Cover: passo 4, immagine 3 di 3
    • Remove a total of four 5mm JIS #000 screws from around the camera:
    • Two screws from the right side.
    • Two screws from the left side.
  5. Kodak PixPro AZ251 Shutter Button Replacement: passo 5, immagine 1 di 1
    • Remove the single 5mm Phillips #00 screw from the bottom.
  6. Kodak PixPro AZ251 Shutter Button Replacement: passo 6, immagine 1 di 2 Kodak PixPro AZ251 Shutter Button Replacement: passo 6, immagine 2 di 2
    • Open the flash module.
    • Remove the two 6mm JIS #00 screws found inside of the flash housing.
  7. Kodak PixPro AZ251 Shutter Button Replacement: passo 7, immagine 1 di 3 Kodak PixPro AZ251 Shutter Button Replacement: passo 7, immagine 2 di 3 Kodak PixPro AZ251 Shutter Button Replacement: passo 7, immagine 3 di 3
    • Use a plastic opening tool to pry apart both halves of the camera.
    • Remove the back panel.
  8. Kodak PixPro AZ251 Shutter Button Replacement, LCD Screen: passo 8, immagine 1 di 2 Kodak PixPro AZ251 Shutter Button Replacement, LCD Screen: passo 8, immagine 2 di 2
    • Remove these three JIS #000 screws from the control board:
    • 5mm screw.
    • 4mm screw.
    • 2mm screw.
  9. Kodak PixPro AZ251 Shutter Button Replacement: passo 9, immagine 1 di 1
    • Pull the small metal switch plate to the side.
  10. Kodak PixPro AZ251 Shutter Button Replacement: passo 10, immagine 1 di 2 Kodak PixPro AZ251 Shutter Button Replacement: passo 10, immagine 2 di 2
    • Pry the LCD screen out of the metal housing plate with a plastic opening tool.
  11. Kodak PixPro AZ251 Shutter Button Replacement: passo 11, immagine 1 di 2 Kodak PixPro AZ251 Shutter Button Replacement: passo 11, immagine 2 di 2
    • Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
    • Pull the orange cable out of the socket.
  12. Kodak PixPro AZ251 Shutter Button Replacement, Shutter Button: passo 12, immagine 1 di 2 Kodak PixPro AZ251 Shutter Button Replacement, Shutter Button: passo 12, immagine 2 di 2
    • Remove one 4mm JIS #000 screw from the top of the camera.
  13. Kodak PixPro AZ251 Shutter Button Replacement: passo 13, immagine 1 di 2 Kodak PixPro AZ251 Shutter Button Replacement: passo 13, immagine 2 di 2
    • Using tweezers, disconnect the orange cable connection at the top of the motherboard.
  14. Kodak PixPro AZ251 Shutter Button Replacement: passo 14, immagine 1 di 2 Kodak PixPro AZ251 Shutter Button Replacement: passo 14, immagine 2 di 2
    • Pull the mode dial up and off of the camera.
    • Rotate carefully to avoid breaking the screw attaching the top side cover to the main body of the camera.
  15. Kodak PixPro AZ251 Shutter Button Replacement: passo 15, immagine 1 di 2 Kodak PixPro AZ251 Shutter Button Replacement: passo 15, immagine 2 di 2
    • Turn camera upside down.
    • Remove the six 2mm JIS #000 screws from the metal base of the shutter button.
  16. Kodak PixPro AZ251 Shutter Button Replacement: passo 16, immagine 1 di 2 Kodak PixPro AZ251 Shutter Button Replacement: passo 16, immagine 2 di 2
    • Remove the metal base and ribbon cables.
  17. Kodak PixPro AZ251 Shutter Button Replacement: passo 17, immagine 1 di 1
    • While holding the shutter button in place, remove the two 4mm JIS #000 screws from the base.
  18. Kodak PixPro AZ251 Shutter Button Replacement: passo 18, immagine 1 di 1
    • Remove the plastic base of the shutter button using tweezers by pulling it straight upward.
  19. Kodak PixPro AZ251 Shutter Button Replacement: passo 19, immagine 1 di 1
    • Remove the shutter button by pulling it out from the bottom side of the top cover.
Conclusione
USF Tampa, Team S1-G1, Cagle Spring 2018 Membro di USF Tampa, Team S1-G1, Cagle Spring 2018
USFT-CAGLE-S18S1G1
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 654
