Salta al contenuto principale
Fix Your Stuff
Right to Repair
Parts & Tools
Introduzione
Removing the back cover of your Kodak PixPro AZ251 gives you access to the camera's LCD screen and motherboard. This guide will instruct you on how to remove the back cover of your Kodak PixPro AZ251.
  1. Slide switch to open lock position. Slide switch to open lock position.
    • Slide switch to open lock position.
  2. Press down on the battery cover and slide outwards to open. Press down on the battery cover and slide outwards to open.
    • Press down on the battery cover and slide outwards to open.
  3. Remove the batteries.
    • Remove the batteries.
  4. Remove a total of four 5mm JIS #000 screws from around the camera: Two screws from the right side. Two screws from the left side.
    • Remove a total of four 5mm JIS #000 screws from around the camera:
    • Two screws from the right side.
    • Two screws from the left side.
  5. Remove the single 5mm Phillips #00 screw from the bottom.
    • Remove the single 5mm Phillips #00 screw from the bottom.
  6. Open the flash module. Remove the two 6mm JIS #00 screws found inside of the flash housing.
    • Open the flash module.
    • Remove the two 6mm JIS #00 screws found inside of the flash housing.
  7. Use a plastic opening tool to pry apart both halves of the camera. Remove the back panel. Remove the back panel.
    • Use a plastic opening tool to pry apart both halves of the camera.
    • Remove the back panel.
Conclusione
Luiza Oliveira
Membro da: 22/02/2018
259 Reputazione
2 Guide realizzate
USF Tampa, Team S1-G1, Cagle Spring 2018 Membro di USF Tampa, Team S1-G1, Cagle Spring 2018
USFT-CAGLE-S18S1G1
4 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 165
