Salta al contenuto principale
Kodak Easyshare Z981 Top Shutter Button Replacement
Cosa ti serve
  1. Kodak Easyshare Z981 Top Shutter Button Replacement, Top Shutter Button: passo 1, immagine 1 di 2 Kodak Easyshare Z981 Top Shutter Button Replacement, Top Shutter Button: passo 1, immagine 2 di 2
    • Open the battery cover and remove the AA batteries from the camera if any are inserted.
  2. Kodak Easyshare Z981 Top Shutter Button Replacement: passo 2, immagine 1 di 2 Kodak Easyshare Z981 Top Shutter Button Replacement: passo 2, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Phillips #00 Screwdriver
    $5.49
    • Remove all screws on the outside of the camera with a 00 Phillips-Head screwdriver
    • Eight (8) 3mm screws on the lower portion of the camera
    • Four (4) screws on the bottom of the camera
    • Four (4) screws inside the battery cover
  3. Kodak Easyshare Z981 Top Shutter Button Replacement: passo 3, immagine 1 di 3 Kodak Easyshare Z981 Top Shutter Button Replacement: passo 3, immagine 2 di 3 Kodak Easyshare Z981 Top Shutter Button Replacement: passo 3, immagine 3 di 3
    • Detach the bottom part of the camera by removing four (4) 3mm screws
    • Two (2) screws are located in the left side of the device
    • Two (2) screws are locatecd in the right side of the device
  4. Kodak Easyshare Z981 Top Shutter Button Replacement: passo 4, immagine 1 di 2 Kodak Easyshare Z981 Top Shutter Button Replacement: passo 4, immagine 2 di 2
    • Use the Plastic Opening Tool to put light pressure and remove the back cover of the camera
    • Be gentle when removing the back cover
  5. Kodak Easyshare Z981 Top Shutter Button Replacement: passo 5, immagine 1 di 3 Kodak Easyshare Z981 Top Shutter Button Replacement: passo 5, immagine 2 di 3 Kodak Easyshare Z981 Top Shutter Button Replacement: passo 5, immagine 3 di 3
    • Unscrew the four (4) 3mm screws to remove the screen from the circuit board
    • Use Tweezers to delicately detach the ribbon cable
    • Carefully remove the screen brace from the circuit board
  6. Kodak Easyshare Z981 Top Shutter Button Replacement: passo 6, immagine 1 di 3 Kodak Easyshare Z981 Top Shutter Button Replacement: passo 6, immagine 2 di 3 Kodak Easyshare Z981 Top Shutter Button Replacement: passo 6, immagine 3 di 3
    • Remove the two (2) 3mm screws from inside flash compartment
    • Remove one (1) 3mm screw from the circuit board
  7. Kodak Easyshare Z981 Top Shutter Button Replacement: passo 7, immagine 1 di 2 Kodak Easyshare Z981 Top Shutter Button Replacement: passo 7, immagine 2 di 2
    • Use the Tweezers to detach the ribbon cable connecter from the circuit board
    • Use the Plastic Opening Tool to gently apply pressure on the top of the camera and remove the upper portion
  8. Kodak Easyshare Z981 Top Shutter Button Replacement: passo 8, immagine 1 di 3 Kodak Easyshare Z981 Top Shutter Button Replacement: passo 8, immagine 2 di 3 Kodak Easyshare Z981 Top Shutter Button Replacement: passo 8, immagine 3 di 3
    • Remove the four (4) 3mm screws from the circuit board directly underneath the shutter button and gently move the circuit board aside
    • Lift up the metal clamp
    • Use caution when removing the circuit board to avoid tearing the wires connected
  9. Kodak Easyshare Z981 Top Shutter Button Replacement: passo 9, immagine 1 di 3 Kodak Easyshare Z981 Top Shutter Button Replacement: passo 9, immagine 2 di 3 Kodak Easyshare Z981 Top Shutter Button Replacement: passo 9, immagine 3 di 3
    • Pull the small brace on top of the shutter button
    • Using the Tweezers, gently remove the shutter button
Conclusione
1Commento della guida
looking for z981 bottom wrist grip jwkcm1978@hotmail.com
jwkcm1978 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 720
