Salta al contenuto principale
Kodak Easyshare Z981 LCD Screen Replacement
Cosa ti serve
  1. Kodak Easyshare Z981 LCD Screen Replacement, LCD Screen: passo 1, immagine 1 di 2 Kodak Easyshare Z981 LCD Screen Replacement, LCD Screen: passo 1, immagine 2 di 2
    • Open the battery cover and remove batteries from the camera if any are inserted.
    Chiedi a FixBot
    Aggiungi Commento
  2. Kodak Easyshare Z981 LCD Screen Replacement: passo 2, immagine 1 di 2 Kodak Easyshare Z981 LCD Screen Replacement: passo 2, immagine 2 di 2
    Strumento utilizzato in questo passaggio:
    Phillips #00 Screwdriver
    $5.49
    • Use a 00 Phillips-Head screwdriver to remove screws:
    • Remove the 3 mm screws from the camera
    • Four (4) screws are in the bottom of the device
    • Four (4) screws are inside the battery cover
    Chiedi a FixBot
    Aggiungi Commento
  3. Kodak Easyshare Z981 LCD Screen Replacement: passo 3, immagine 1 di 1
    • Start from a corner and gently remove the cover.
    • The cover will easily lift off, so not much pressure is required.
    • Make sure to gently remove the bottom cover in order to avoid breaking the plastic.
    Chiedi a FixBot
    Aggiungi Commento
  4. Kodak Easyshare Z981 LCD Screen Replacement: passo 4, immagine 1 di 2 Kodak Easyshare Z981 LCD Screen Replacement: passo 4, immagine 2 di 2
    $5.49
    • Use a Phillips #00 Screwdriver to remove the 4 mm screws from each side of the back cover of the camera.
    • Two (2) screws are located in the left side of the device
    • Two (2) screws are locatecd in the right side of the device
    Chiedi a FixBot
    Aggiungi Commento
  5. Kodak Easyshare Z981 LCD Screen Replacement: passo 5, immagine 1 di 2 Kodak Easyshare Z981 LCD Screen Replacement: passo 5, immagine 2 di 2
    • Insert the Plastic Opening Tool in to the crevices of back cover and gently apply pressure
    • Be gentle while removing the cover, to avoid cracking the case
    Chiedi a FixBot
    Aggiungi Commento
  6. Kodak Easyshare Z981 LCD Screen Replacement: passo 6, immagine 1 di 2 Kodak Easyshare Z981 LCD Screen Replacement: passo 6, immagine 2 di 2
    • Once the back cover is removed locate the four 3mm screws holding the screen and the metal brace to the circuit board
    Chiedi a FixBot
    Aggiungi Commento
  7. Kodak Easyshare Z981 LCD Screen Replacement: passo 7, immagine 1 di 3 Kodak Easyshare Z981 LCD Screen Replacement: passo 7, immagine 2 di 3 Kodak Easyshare Z981 LCD Screen Replacement: passo 7, immagine 3 di 3
    • Gently lift up the metal brace and use a pair of tweezers to disconnect the ribbon cable connector.
    • Remove the screen brace from the circuit board.
    • Use extreme caution when removing the LCD brace; pulling the brace may tear the cable.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 7
Ultimi 30 giorni: 19
Tutti i Tempi: 947
