Salta al contenuto principale
Kodak Easyshare Z981 Flash Button Replacement
Cosa ti serve
  1. Kodak Easyshare Z981 Flash Button Replacement, Flash Button: passo 1, immagine 1 di 2 Kodak Easyshare Z981 Flash Button Replacement, Flash Button: passo 1, immagine 2 di 2
    • Open the battery cover and remove the AA batteries from the camera if any are inserted.
    • Remove screws using a 00 Phillips-Head screwdriver:
    • Eight (8) 3mm screws on the lower portion of the camera
    • Four (4) on the bottom of the camera
    • Four (4) on the inside of the battery cover
    • Four (4) 6mm screws on the sides of the camera (two on each side)
  2. Kodak Easyshare Z981 Flash Button Replacement: passo 3, immagine 1 di 1
    • Start from a corner and gently remove the bottom of the camera.
    • The cover will easily lift off, so not much pressure is required.
  3. Kodak Easyshare Z981 Flash Button Replacement: passo 4, immagine 1 di 2 Kodak Easyshare Z981 Flash Button Replacement: passo 4, immagine 2 di 2
    • Use a Plastic Opening Tool to remove the back of the camera
    • Remove the four (4) 3mm screws attaching the LCD screen to the circuit board.
    • Use Tweezers to carefully detach the ribbon cable
    • Use extreme caution on this step, as the ribbon cable is very fragile and can rip very easily.
  4. Kodak Easyshare Z981 Flash Button Replacement: passo 6, immagine 1 di 3 Kodak Easyshare Z981 Flash Button Replacement: passo 6, immagine 2 di 3 Kodak Easyshare Z981 Flash Button Replacement: passo 6, immagine 3 di 3
    • Open the flash compartment and remove two (2) 3mm screws.
  5. Kodak Easyshare Z981 Flash Button Replacement: passo 7, immagine 1 di 2 Kodak Easyshare Z981 Flash Button Replacement: passo 7, immagine 2 di 2
    • Use a Plastic Opening Tool to carefully remove the top of the camera.
    • Use caution when removing the top of the camera
  6. Kodak Easyshare Z981 Flash Button Replacement: passo 8, immagine 1 di 3 Kodak Easyshare Z981 Flash Button Replacement: passo 8, immagine 2 di 3 Kodak Easyshare Z981 Flash Button Replacement: passo 8, immagine 3 di 3
    • Remove four (4) 3mm screws from the circuit board underneath the button set.
    • Gently move the circuit board aside.
    • Gently move aside the metal sheet.
    • Use Tweezers to carefully remove the flash button.
    • The button should simply pop out when light pressure is applied.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 606
