Salta al contenuto principale
Kodak Easyshare Z981 Bottom Panel Replacement
Cosa ti serve
  1. Kodak Easyshare Z981 Bottom Panel Replacement, Bottom Panel: passo 1, immagine 1 di 2 Kodak Easyshare Z981 Bottom Panel Replacement, Bottom Panel: passo 1, immagine 2 di 2
    • Open the battery cover and remove the AA batteries from the camera if any are inserted.
    • Use a 00 Phillips-Head screwdriver
    • Remove the 3 mm screws from the camera.
    • Four (4) screws are in the bottom of the device
    • Four (4) screws are inside the battery cover
  2. Kodak Easyshare Z981 Bottom Panel Replacement: passo 3, immagine 1 di 1
    • Start from a corner and gently remove the bottom cover.
    • The cover will easily lift off, so not much pressure is required.
    • Be gentle while removing the cover, to avoid breaking the plastic
  3. Kodak Easyshare Z981 Bottom Panel Replacement: passo 4, immagine 1 di 3 Kodak Easyshare Z981 Bottom Panel Replacement: passo 4, immagine 2 di 3 Kodak Easyshare Z981 Bottom Panel Replacement: passo 4, immagine 3 di 3
    • Remove the bottom of the battery cover first, and then the top.
    • The hinge is simple, the screwdriver is no longer necessary.
Conclusione
Altre 5 persone hanno completato questa guida.
6 Commenti
where can i buy it?
Lizette Nin - Replica
PLEASE help? I can't find this part anywhere?
thecarlisles - Replica
Did anyone ever find the parts to complete this task? It's exactly what I need to do but cant find the bottom plate anywhere.
Billy T - Replica
I need the bottom panel also. If anyone knows where to purchase it please email me kpw1god@yahoo.com
kpw1god - Replica
I HAVE THE SAME QUESTION. WHERE  ARE THE PARTS BOUGHT??????? WHY PUT THIS OUT  IF U CAN’T BUY THE PARTS?? bILL     RENTMRBILL@YAHOO.COM
rentmrbill - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 22
Tutti i Tempi: 2,022
