Salta al contenuto principale
Kodak Easyshare Z981 Back Cover Replacement
Cosa ti serve
    • Remove screws using a 00 Phillips-Head screwdriver:
    • Eight (8) 3mm screws on the lower portion of the camera
    • Four (4) on the bottom of the camera
    • Four (4) inside the battery cover
  1. Kodak Easyshare Z981 Back Cover Replacement: passo 2, immagine 1 di 1
    • Start from a corner and gently remove the bottom cover of the camera.
    • The cover will easily lift off without much pressure necessary.
    • Use a Phillips #00 Screwdriver to remove the 4 mm screws from each side of the back cover of the camera.
    • Two (2) screws are located in the left side of the device
    • Two (2) screws are locatecd in the right side of the device
  2. Kodak Easyshare Z981 Back Cover Replacement: passo 4, immagine 1 di 2 Kodak Easyshare Z981 Back Cover Replacement: passo 4, immagine 2 di 2
    • Use a Plastic Opening Tool to remove the back of the camera and pull gently on the cover to remove the cover
    • Start from one corner and apply light pressure with the tool.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 533
