Salta al contenuto principale
Kodak Easyshare V1003 Lens Replacement
Cosa ti serve
  1. Kodak Easyshare V1003 Lens  Replacement, Battery: passo 1, immagine 1 di 1
    • Turn off camera by firmly pressing the power button that is located on the top of the camera.
  2. Kodak Easyshare V1003 Lens  Replacement: passo 2, immagine 1 di 1
    • Position camera with the bottom facing up.
  3. Kodak Easyshare V1003 Lens  Replacement: passo 3, immagine 1 di 1
    • With your finger, slide the battery cover in the direction of the open arrow.
  4. Kodak Easyshare V1003 Lens  Replacement: passo 4, immagine 1 di 1
    • Lift the battery cover up gently.
  5. Kodak Easyshare V1003 Lens  Replacement: passo 5, immagine 1 di 2 Kodak Easyshare V1003 Lens  Replacement: passo 5, immagine 2 di 2
    • Gently push the battery down until a click is heard. Battery should release and be lifted out of slot.
  6. Kodak Easyshare V1003 Lens  Replacement, Lens: passo 6, immagine 1 di 2 Kodak Easyshare V1003 Lens  Replacement, Lens: passo 6, immagine 2 di 2
    • Use a J00 screwdriver to remove the five exterior screws.
  7. Kodak Easyshare V1003 Lens  Replacement: passo 7, immagine 1 di 1
    • Pull the outer case off using the plastic opening tool.
  8. Kodak Easyshare V1003 Lens  Replacement: passo 8, immagine 1 di 2 Kodak Easyshare V1003 Lens  Replacement: passo 8, immagine 2 di 2
    • Remove the LCD display by unplugging the connector
    • Take apart the LCD display from the back case
  9. Kodak Easyshare V1003 Lens  Replacement: passo 9, immagine 1 di 2 Kodak Easyshare V1003 Lens  Replacement: passo 9, immagine 2 di 2
    • Peel off the yellow film.
    • Peel off the black tape holding the wires.
  10. Kodak Easyshare V1003 Lens  Replacement: passo 10, immagine 1 di 1
    • Unplug the connector by lifting the little lock holding it in place.
  11. Kodak Easyshare V1003 Lens  Replacement: passo 11, immagine 1 di 2 Kodak Easyshare V1003 Lens  Replacement: passo 11, immagine 2 di 2
    • Use a J00 screwdriver to remove two screws located on the far right, near to the main button.
  12. Kodak Easyshare V1003 Lens  Replacement: passo 12, immagine 1 di 3 Kodak Easyshare V1003 Lens  Replacement: passo 12, immagine 2 di 3 Kodak Easyshare V1003 Lens  Replacement: passo 12, immagine 3 di 3
    • Use a J00 screwdriver to remove 6 screws located at the center of the back panel.
    • Gently pull out the lens using you finger tips or pincers.
Conclusione
Sarah Berry
Membro da: 03/21/17
313 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 398
