Salta al contenuto principale
Kodak Easyshare C183 Lens Assembly Replacement
Cosa ti serve
  1. Kodak Easyshare C183 Lens Assembly Replacement, Lens: passo 1, immagine 1 di 3 Kodak Easyshare C183 Lens Assembly Replacement, Lens: passo 1, immagine 2 di 3 Kodak Easyshare C183 Lens Assembly Replacement, Lens: passo 1, immagine 3 di 3
    • Remove the batteries, memory card and wrist strap, if so equipped.
    • Remove the three Phillips screws on the bottom.
    • Remove the two Phillips screws on the right hand side.
  2. Kodak Easyshare C183 Lens Assembly Replacement: passo 2, immagine 1 di 3 Kodak Easyshare C183 Lens Assembly Replacement: passo 2, immagine 2 di 3 Kodak Easyshare C183 Lens Assembly Replacement: passo 2, immagine 3 di 3
    • Remove the two screws on the left hand side.
    • Nicely enough, all the screws are the same size. No need to keep them separated.
    • Start splitting the case from the battery holder. You can use an opening tool or just your fingernails.
  3. Kodak Easyshare C183 Lens Assembly Replacement: passo 3, immagine 1 di 3 Kodak Easyshare C183 Lens Assembly Replacement: passo 3, immagine 2 di 3 Kodak Easyshare C183 Lens Assembly Replacement: passo 3, immagine 3 di 3
    • The camera's front half will come off first.
    • Remove the one screw on the top left of the camera. It this holds the back case on to the midframe.
    • Remove the back case.
  4. Kodak Easyshare C183 Lens Assembly Replacement: passo 4, immagine 1 di 3 Kodak Easyshare C183 Lens Assembly Replacement: passo 4, immagine 2 di 3 Kodak Easyshare C183 Lens Assembly Replacement: passo 4, immagine 3 di 3
    • Gently move the LCD out of the holder. DO NOT TRY TO REMOVE THE LCD. Just fold it over.
    • Remove the one screw on the top corner of the holder.
    • Remove the ribbon cable from its connector. It is just pushed in. there are not clips to move. Gently pull it straight down.
    • Remove the solder that connects the LCD holder to the top logic board.
  5. Kodak Easyshare C183 Lens Assembly Replacement: passo 5, immagine 1 di 3 Kodak Easyshare C183 Lens Assembly Replacement: passo 5, immagine 2 di 3 Kodak Easyshare C183 Lens Assembly Replacement: passo 5, immagine 3 di 3
    • The LCD holding board and the switches are removed as one unit.
    • Open the clip on the LCD ribbon cable connector. Use your fingernails to gently pull it toward the top of the camera.
    • Remove the LCD.
  6. Kodak Easyshare C183 Lens Assembly Replacement: passo 6, immagine 1 di 3 Kodak Easyshare C183 Lens Assembly Replacement: passo 6, immagine 2 di 3 Kodak Easyshare C183 Lens Assembly Replacement: passo 6, immagine 3 di 3
    • Open the connectors for the CCD and the lens. Both use a clip that hold the cable is places. Move those gently into the opposite direction of the cables. this will free the cable.
    • Remove the two screws that hold the lens in place.
    • With the screws and the cables removed, use your fingers and push the lens upward and angled out of the midframe.
  7. Kodak Easyshare C183 Lens Assembly Replacement: passo 7, immagine 1 di 1
    • This is what your final result should look like. the lens is now free from the midframe and a new lens can be easily installed.
Conclusione
oldturkey03
Membro da: 09/29/10
782.427 Reputazione
119 Guide realizzate
Global Fixers Membro di Global Fixers
Community
33 Membri
544 Guide realizzate
2 Commenti
ممنون از اطلاعات تان
hamid kaker - Replica
خواهش میکنم. امیدوارم کمک کرده باشد.
oldturkey03 -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 1,842
