Cosa ti serve
Remove the batteries, memory card and wrist strap, if so equipped.
Remove the three Phillips screws on the bottom.
Remove the two Phillips screws on the right hand side.
Gently move the LCD out of the holder. DO NOT TRY TO REMOVE THE LCD. Just fold it over.
Remove the one screw on the top corner of the holder.
Remove the ribbon cable from its connector. It is just pushed in. there are not clips to move. Gently pull it straight down.
Remove the solder that connects the LCD holder to the top logic board.
Open the connectors for the CCD and the lens. Both use a clip that hold the cable is places. Move those gently into the opposite direction of the cables. this will free the cable.
Remove the two screws that hold the lens in place.
With the screws and the cables removed, use your fingers and push the lens upward and angled out of the midframe.
Altre 2 persone hanno completato questa guida.
2 Commenti
ممنون از اطلاعات تان
خواهش میکنم. امیدوارم کمک کرده باشد.
