Salta al contenuto principale
Kodak EasyShare Z1015 IS SD Memory Card Replacement
Cosa ti serve
  1. Kodak EasyShare Z1015 IS SD Memory Card Replacement, SD Memory Card: passo 1, immagine 1 di 2 Kodak EasyShare Z1015 IS SD Memory Card Replacement, SD Memory Card: passo 1, immagine 2 di 2
    • In order to remove the SD memory card, you will first need to open up the cover. To open the cover, slide the latch holding the cover in place to the left.
    • Remove your hand from the latch and the cover should pop open. The SD memory card is located near the top above the battery. As shown in the final picture of this step.
  2. Kodak EasyShare Z1015 IS SD Memory Card Replacement: passo 2, immagine 1 di 2 Kodak EasyShare Z1015 IS SD Memory Card Replacement: passo 2, immagine 2 di 2
    • After locating the SD card, gently push down on the card and release. This will cause the SD card to pop out of its position in the camera as shown in the second picture of this step.
  3. Kodak EasyShare Z1015 IS SD Memory Card Replacement: passo 3, immagine 1 di 2 Kodak EasyShare Z1015 IS SD Memory Card Replacement: passo 3, immagine 2 di 2
    • After removing the SD card from its locked position, gently pull the SD card out from the container to successfully remove it from the camera.
Conclusione
katie newman
Membro da: 10/28/10
30 Reputazione
3 Guide realizzate
Cal Poly, Team 5-16, Maness Fall 2010 Membro di Cal Poly, Team 5-16, Maness Fall 2010
CPSU-MANESS-F10S5G16
4 Membri
11 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 24
Tutti i Tempi: 2,811
