Salta al contenuto principale
Kodak EasyShare Z1015 IS LCD Replacement
Cosa ti serve
  1. Kodak EasyShare Z1015 IS LCD Replacement, Battery: passo 1, immagine 1 di 2 Kodak EasyShare Z1015 IS LCD Replacement, Battery: passo 1, immagine 2 di 2
    • Begin by sliding the switch towards the open symbol. Release your finger from the switch and the battery case will pop open.
  2. Kodak EasyShare Z1015 IS LCD Replacement: passo 2, immagine 1 di 1
    • Next, press down on the red lever which holds the battery in place.
  3. Kodak EasyShare Z1015 IS LCD Replacement: passo 3, immagine 1 di 2 Kodak EasyShare Z1015 IS LCD Replacement: passo 3, immagine 2 di 2
    • Once the battery has popped out of the compartment, simply pull it out of the camera.
  4. Kodak EasyShare Z1015 IS LCD Replacement, Back Cover: passo 4, immagine 1 di 3 Kodak EasyShare Z1015 IS LCD Replacement, Back Cover: passo 4, immagine 2 di 3 Kodak EasyShare Z1015 IS LCD Replacement, Back Cover: passo 4, immagine 3 di 3
    • Make sure that the lens cover is on the Kodak EasyShare whenever working with one of these guides.
    • Also, make sure to keep track of the screws you remove throughout these step by step guides. Losing a screw could inhibit the ability to reassemble the camera.
    • Begin by removing the first screw located on the back of the camera.
  5. Kodak EasyShare Z1015 IS LCD Replacement: passo 5, immagine 1 di 2 Kodak EasyShare Z1015 IS LCD Replacement: passo 5, immagine 2 di 2
    • Next, remove the two screws located on the right side of the camera.
  6. Kodak EasyShare Z1015 IS LCD Replacement: passo 6, immagine 1 di 2 Kodak EasyShare Z1015 IS LCD Replacement: passo 6, immagine 2 di 2
    • After removing the screws located on the right side, remove the six screws located on the bottom of the camera.
  7. Kodak EasyShare Z1015 IS LCD Replacement: passo 7, immagine 1 di 2 Kodak EasyShare Z1015 IS LCD Replacement: passo 7, immagine 2 di 2
    • Lastly, remove the two screws located on the left side of the camera.
  8. Kodak EasyShare Z1015 IS LCD Replacement: passo 8, immagine 1 di 3 Kodak EasyShare Z1015 IS LCD Replacement: passo 8, immagine 2 di 3 Kodak EasyShare Z1015 IS LCD Replacement: passo 8, immagine 3 di 3
    • Once all eleven screws have been removed, use Plastic Opening Tools to take off the back cover.
    • Insert the plastic opening tool and apply leverage on each side of the camera. The recommended spots to apply leverage are shown in these pictures.
  9. Kodak EasyShare Z1015 IS LCD Replacement: passo 9, immagine 1 di 3 Kodak EasyShare Z1015 IS LCD Replacement: passo 9, immagine 2 di 3 Kodak EasyShare Z1015 IS LCD Replacement: passo 9, immagine 3 di 3
    • Apply pressure on the left and right side of the camera and pull the back cover away from the device.
    • Once the back cover has been successfully removed, you should have a total of eleven screws as well as the bottom cover separated from the camera.
  10. Kodak EasyShare Z1015 IS LCD Replacement, LCD: passo 10, immagine 1 di 2 Kodak EasyShare Z1015 IS LCD Replacement, LCD: passo 10, immagine 2 di 2
    • Begin by using Plastic Opening Tools to remove the LCD Screen from it's interior casing. To do this, place the opening tool in between the screen and casing and apply leverage to remove the screen. Do this around the rim of the casing, especially where orange squares appear in the pictures.
  11. Kodak EasyShare Z1015 IS LCD Replacement: passo 11, immagine 1 di 1
    • Gently remove the LCD screen from it's interior casing by lifting and pulling from the right side.
    • Be incredibly cautious not to pull to hard on the screen, doing so may rip the ribbon that connects the screen to the logic board and permanently damage your camera.
  12. Kodak EasyShare Z1015 IS LCD Replacement: passo 12, immagine 1 di 3 Kodak EasyShare Z1015 IS LCD Replacement: passo 12, immagine 2 di 3 Kodak EasyShare Z1015 IS LCD Replacement: passo 12, immagine 3 di 3
    • To completely remove the LCD screen from the interior of the camera, you must unhook the ribbon from the logic board.
    • To do this, simply lift up the tab connecting the ribbon to the logic board and pull gently on the LCD screen.
Conclusione
katie newman
Membro da: 10/28/10
30 Reputazione
3 Guide realizzate
Cal Poly, Team 5-16, Maness Fall 2010 Membro di Cal Poly, Team 5-16, Maness Fall 2010
CPSU-MANESS-F10S5G16
4 Membri
11 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 2,913
