Introduzione
The internal frame of the Kodak EasyShare Z1015 IS separates the logic board from the LCD screen. To remove it from the camera, follow this guide.
Cosa ti serve
Begin by sliding the switch towards the open symbol. Release your finger from the switch and the battery case will pop open.
Lastly, remove the two screws located on the left side of the camera.
Trés bon tuto !!! bravo
Aprés, comment réparer les contacts des touches de selection ,
Begin by using Plastic Opening Tools to remove the LCD Screen from it's interior casing. To do this, place the opening tool in between the screen and casing and apply leverage to remove the screen. Do this around the rim of the casing, especially where orange squares appear in the pictures.
Begin by unscrewing all four screws found in each corner of the frame
Altre 2 persone hanno completato questa guida.
Un commento
I have a Kodac DX7630 and a Kodac DX4530 both with the same problem..the monitor is black.The rest functions perfectly.Cam they be repaired and will there still be parts available?
Many thanks
Denzil
