Salta al contenuto principale
Kodak EasyShare V570 Case Replacement
Cosa ti serve
  1. Kodak EasyShare V570 Case Replacement, Case: passo 1, immagine 1 di 2 Kodak EasyShare V570 Case Replacement, Case: passo 1, immagine 2 di 2
    • Here is the front, back, and right side of the camera.
  2. Kodak EasyShare V570 Case Replacement: passo 2, immagine 1 di 3 Kodak EasyShare V570 Case Replacement: passo 2, immagine 2 di 3 Kodak EasyShare V570 Case Replacement: passo 2, immagine 3 di 3
    • There are going to be four #000 screws on the left side of the camera.
    • Remove the four corner screws using a Philips #000 Screwdriver.
    • On the right side of the camera, remove the two Phillips #000 screws at the bottom.
    • On the underside of the camera, remove the three Phillips #000 screws.
  3. Kodak EasyShare V570 Case Replacement: passo 3, immagine 1 di 3 Kodak EasyShare V570 Case Replacement: passo 3, immagine 2 di 3 Kodak EasyShare V570 Case Replacement: passo 3, immagine 3 di 3
    • As soon as all the screws from the casing are removed, use the iFixit opening pick to slide around the border.
    • If the cover appears loose, try to take it off (with your fingers) while slightly wiggling it, and it should detach.
  4. Kodak EasyShare V570 Case Replacement: passo 4, immagine 1 di 2 Kodak EasyShare V570 Case Replacement: passo 4, immagine 2 di 2
    • Here is what the camera looks like with both of the covers taken off.
    • The T-W button is upside down.
    • To put the top and back camera covers back on, follow the steps but in reverse.
Linea Traguardo
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 9
Tutti i Tempi: 100
