Salta al contenuto principale
Kodak EasyShare V570 Battery Replacement
  1. Kodak EasyShare V570 Battery Replacement, Battery: passo 1, immagine 1 di 3 Kodak EasyShare V570 Battery Replacement, Battery: passo 1, immagine 2 di 3 Kodak EasyShare V570 Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Turn off your camera before beginning the replacement.
    • Take a finger or two and slide back the compartment where the battery will be and lift it up.
  2. Kodak EasyShare V570 Battery Replacement: passo 2, immagine 1 di 2 Kodak EasyShare V570 Battery Replacement: passo 2, immagine 2 di 2
    • Be careful when pulling back the brown tap it can be a little tricky.
    • Push back the brown tab with your finger.
  3. Kodak EasyShare V570 Battery Replacement: passo 3, immagine 1 di 3 Kodak EasyShare V570 Battery Replacement: passo 3, immagine 2 di 3 Kodak EasyShare V570 Battery Replacement: passo 3, immagine 3 di 3
    • Take out the old battery from its compartment with 2 fingers
    • If it doesn't come out that way turn the camera towards you and let it slide out onto your hand.
  4. Kodak EasyShare V570 Battery Replacement: passo 4, immagine 1 di 2 Kodak EasyShare V570 Battery Replacement: passo 4, immagine 2 di 2
    • Insert the new battery by pulling down the brown mark.
    • Grab the new battery and insert it into the battery compartment
    • Please do not use force while inserting the new battery.
    • Make sure that the battery has its corner facing down and inwards at the camera.
  5. Kodak EasyShare V570 Battery Replacement: passo 5, immagine 1 di 3 Kodak EasyShare V570 Battery Replacement: passo 5, immagine 2 di 3 Kodak EasyShare V570 Battery Replacement: passo 5, immagine 3 di 3
    • Be careful to not use too much force.
    • Lightly push the cover down and slide it inward.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 6
Tutti i Tempi: 102
