Salta al contenuto principale
Kodak EasyShare M532 Screen Replacement
Cosa ti serve
  1. Kodak EasyShare M532 Screen  Replacement, Screen: passo 1, immagine 1 di 2 Kodak EasyShare M532 Screen  Replacement, Screen: passo 1, immagine 2 di 2
    • Open the battery compartment on the bottom of the camera and remove the battery.
  2. Kodak EasyShare M532 Screen  Replacement: passo 2, immagine 1 di 3 Kodak EasyShare M532 Screen  Replacement: passo 2, immagine 2 di 3 Kodak EasyShare M532 Screen  Replacement: passo 2, immagine 3 di 3
    • Remove two Phillips screws from each side of the camera (four screws total).
    • Remove one additional Phillips screw from the bottom of the camera.
  3. Kodak EasyShare M532 Screen  Replacement: passo 3, immagine 1 di 3 Kodak EasyShare M532 Screen  Replacement: passo 3, immagine 2 di 3 Kodak EasyShare M532 Screen  Replacement: passo 3, immagine 3 di 3
    • Inserting the prying tool as shown, gently separate the front and back pieces of the camera exterior.
  4. Kodak EasyShare M532 Screen  Replacement: passo 4, immagine 1 di 3 Kodak EasyShare M532 Screen  Replacement: passo 4, immagine 2 di 3 Kodak EasyShare M532 Screen  Replacement: passo 4, immagine 3 di 3
    • Carefully remove the front and back exterior pieces from the camera body.
  5. Kodak EasyShare M532 Screen  Replacement: passo 5, immagine 1 di 3 Kodak EasyShare M532 Screen  Replacement: passo 5, immagine 2 di 3 Kodak EasyShare M532 Screen  Replacement: passo 5, immagine 3 di 3
    • Gently remove the frame with the top buttons.
    • You should now have the screen and inside parts exposed as shown.
  6. Kodak EasyShare M532 Screen  Replacement: passo 6, immagine 1 di 2 Kodak EasyShare M532 Screen  Replacement: passo 6, immagine 2 di 2
    • Lift the screen off the body. Note that it is still connected on one side by the orange tape.
    • Flip it over gently and let it rest off to the side where the tape is.
    • It is okay if the orange tape clips out of its spot.
  7. Kodak EasyShare M532 Screen  Replacement: passo 7, immagine 1 di 2 Kodak EasyShare M532 Screen  Replacement: passo 7, immagine 2 di 2
    • Remove the two Phillips screws. There is one at the top center and one in the bottom left corner.
  8. Kodak EasyShare M532 Screen  Replacement: passo 8, immagine 1 di 3 Kodak EasyShare M532 Screen  Replacement: passo 8, immagine 2 di 3 Kodak EasyShare M532 Screen  Replacement: passo 8, immagine 3 di 3
    • Remove the top Phillips screw from the right side.
    • Move the silver tape aside to access and remove the Phillips screw in the bottom corner.
  9. Kodak EasyShare M532 Screen  Replacement: passo 9, immagine 1 di 3 Kodak EasyShare M532 Screen  Replacement: passo 9, immagine 2 di 3 Kodak EasyShare M532 Screen  Replacement: passo 9, immagine 3 di 3
    • Gently pry up the clip on the top corner to release the metal casing and lift the casing out of the way.
    • The casing is also connected via an orange tape on the right side that you may leave in place.
    • Be sure to wear safety glasses while prying the clip.
  10. Kodak EasyShare M532 Screen  Replacement: passo 10, immagine 1 di 3 Kodak EasyShare M532 Screen  Replacement: passo 10, immagine 2 di 3 Kodak EasyShare M532 Screen  Replacement: passo 10, immagine 3 di 3
    • Find the silver clip where the orange tape from the screen attaches to the circuit board.
    • Lift up the silver clip. The orange tape will slide out, completely disconnecting the screen from the camera.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 10
Tutti i Tempi: 767
