Salta al contenuto principale
Kodak EasyShare M381 Screen Replacement
Cosa ti serve
  1. Kodak EasyShare M381 Screen Replacement, Battery: passo 1, immagine 1 di 2 Kodak EasyShare M381 Screen Replacement, Battery: passo 1, immagine 2 di 2
    • First, press in and slide forward the battery latch as indicated by the arrow.
  2. Kodak EasyShare M381 Screen Replacement: passo 2, immagine 1 di 1
    • Press down on battery until you hear a click and release it. Battery should easily slide out.
  3. Kodak EasyShare M381 Screen Replacement, Back Panel Frame: passo 3, immagine 1 di 3 Kodak EasyShare M381 Screen Replacement, Back Panel Frame: passo 3, immagine 2 di 3 Kodak EasyShare M381 Screen Replacement, Back Panel Frame: passo 3, immagine 3 di 3
    • Remove the 3.9 mm frame screws using a Phillips #00 screwdriver.
    • Using a magnetized surface to keep from losing screws may be very helpful.
  4. Kodak EasyShare M381 Screen Replacement: passo 4, immagine 1 di 2 Kodak EasyShare M381 Screen Replacement: passo 4, immagine 2 di 2
    • Using both hands, carefully pull the frame apart from the camera.
  5. Kodak EasyShare M381 Screen Replacement, Screen: passo 5, immagine 1 di 1
    • Remove the two 3.85 mm screws on the bottom right of the camera, as indicated.
  6. Kodak EasyShare M381 Screen Replacement: passo 6, immagine 1 di 1
    • Remove dial button located on top of camera, by gently pulling up.
  7. Kodak EasyShare M381 Screen Replacement: passo 7, immagine 1 di 2 Kodak EasyShare M381 Screen Replacement: passo 7, immagine 2 di 2
    • Starting at one side, carefully work the chrome frame off of the camera itself.
    • Be careful not to disturb the shutter or flash buttons on top of the camera.
  8. Kodak EasyShare M381 Screen Replacement: passo 8, immagine 1 di 1
    • On the right side of the camera, locate and remove the two 3.25 mm screws as highlighted.
  9. Kodak EasyShare M381 Screen Replacement: passo 9, immagine 1 di 3 Kodak EasyShare M381 Screen Replacement: passo 9, immagine 2 di 3 Kodak EasyShare M381 Screen Replacement: passo 9, immagine 3 di 3
    • Carefully lift the motherboard panel up, pulling towards the left. Make sure you do not rip the blue ribbon.
    • Using a plastic opening tool, gently lift up on the ribbon fastener until it is in an upright position.
    • Slide panel away from camera.
  10. Kodak EasyShare M381 Screen Replacement: passo 10, immagine 1 di 2 Kodak EasyShare M381 Screen Replacement: passo 10, immagine 2 di 2
    • Using a plastic opening tool, gently lift ribbon clamp as indicated to remove the screen ribbon from the motherboard.
    • Screen should now be detached. Gently lift it away from the base of the camera.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 8
Tutti i Tempi: 452
