Salta al contenuto principale
Kodak EasyShare M381 Button Replacement
Cosa ti serve
  1. Kodak EasyShare M381 Button Replacement, Battery: passo 1, immagine 1 di 2 Kodak EasyShare M381 Button Replacement, Battery: passo 1, immagine 2 di 2
    • First, press in and slide forward the battery latch as indicated by the arrow.
  2. Kodak EasyShare M381 Button Replacement: passo 2, immagine 1 di 1
    • Press down on battery until you hear a click and release it. Battery should easily slide out.
  3. Kodak EasyShare M381 Button Replacement, Back Panel Frame: passo 3, immagine 1 di 3 Kodak EasyShare M381 Button Replacement, Back Panel Frame: passo 3, immagine 2 di 3 Kodak EasyShare M381 Button Replacement, Back Panel Frame: passo 3, immagine 3 di 3
    • Remove the 3.9 mm frame screws using a Phillips #00 screwdriver.
    • Using a magnetized surface to keep from losing screws may be very helpful.
  4. Kodak EasyShare M381 Button Replacement: passo 4, immagine 1 di 2 Kodak EasyShare M381 Button Replacement: passo 4, immagine 2 di 2
    • Using both hands, carefully pull the frame apart from the camera.
  5. Kodak EasyShare M381 Button Replacement, Button: passo 5, immagine 1 di 1
    • Carefully pick up frame and push upward on buttons.
  6. Kodak EasyShare M381 Button Replacement: passo 6, immagine 1 di 1
    • Clean and replace as needed.
    • A microfiber cloth, or any other type of electronic cloth may be used to clean them if desire.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 277
