Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Parti
Nessuna parte specificata.
  1. Place thumb firmly on battery cover. Slide thumb right, the cover should follow and pop up.
    • Place thumb firmly on battery cover.
    • Slide thumb right, the cover should follow and pop up.
  2. Place thumb on orange tab and pull back towards screen. The battery should pop up.
    • Place thumb on orange tab and pull back towards screen.
    • The battery should pop up.
    • Gently lift battery out.
  3. Remove screws from along outer edge of casing. There are 6 screws in total. Righty tighty, lefty loosey!
    • Remove screws from along outer edge of casing.
    • There are 6 screws in total.
    • Righty tighty, lefty loosey!
  4. Gently lift off front and back casing. Gently lift off front and back casing. Gently lift off front and back casing.
    • Gently lift off front and back casing.
  5. Remove screws along side. Gently peel off side casing. Gently peel off side casing.
    • Remove screws along side.
    • Gently peel off side casing.
  6. Remove screws from front silver panel. Remove screws from front silver panel. Remove screws from front silver panel.
    • Remove screws from front silver panel.
  7. Lift up ribbon cable fastener with blue plastic opening tool. Gently pull out lens. Gently pull out lens.
    • Lift up ribbon cable fastener with blue plastic opening tool.
    • Gently pull out lens.
  8. To place new lens, peel off silver tape before inserting ribbon cable into proper slot.
    • To place new lens, peel off silver tape before inserting ribbon cable into proper slot.
Conclusione
Brian
Membro da: 13/03/2014
252 Reputazione
2 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 164
