Salta al contenuto principale
Fix Your Stuff
Right to Repair
Parts & Tools
Parti
Nessuna parte specificata.
  1. Place thumb firmly on battery cover. Slide thumb right, the cover should follow and pop up.
    • Place thumb firmly on battery cover.
    • Slide thumb right, the cover should follow and pop up.
  2. Place thumb on orange tab and pull back towards screen. The battery should pop up.
    • Place thumb on orange tab and pull back towards screen.
    • The battery should pop up.
    • Gently lift battery out.
  3. Remove screws from along outer edge of casing. There are 6 screws in total. Righty tighty, lefty loosey!
    • Remove screws from along outer edge of casing.
    • There are 6 screws in total.
    • Righty tighty, lefty loosey!
  4. Gently lift off front and back casing. Gently lift off front and back casing. Gently lift off front and back casing.
    • Gently lift off front and back casing.
  5. Remove screws along side. Gently peel off side casing. Gently peel off side casing.
    • Remove screws along side.
    • Gently peel off side casing.
  6. Open the battery door and identify the retaining pin. Push retaining pin out with small tweezers. Push retaining pin out with small tweezers.
    • Open the battery door and identify the retaining pin.
    • Push retaining pin out with small tweezers.
  7. Once pin is out halfway, close door to ensure no loose parts get lost. Continue to pull out the remaining length of the pin. Continue to pull out the remaining length of the pin.
    • Once pin is out halfway, close door to ensure no loose parts get lost.
    • Continue to pull out the remaining length of the pin.
  8. Gently lift off door cover. Gently lift off door cover.
    • Gently lift off door cover.
Conclusione
Kyanna
Membro da: 13/03/2014
313 Reputazione
3 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 58
