Introduzione
Replace unusable or damaged button.
Parti
Nessuna parte richiesta.
  1. Open the battery cover.
    • Open the battery cover.
  2. Slide the orange latch sideways to eject the battery.
    • Slide the orange latch sideways to eject the battery.
    • Remove the battery.
  3. Remove 7 screws. 1 (6.25 mm) screw located on the top right corner, next to the view screen. 4 (4.45mm) screws on the bottom of the camera.
    • Remove 7 screws.
      • 1 (6.25 mm) screw located on the top right corner, next to the view screen.
      • 4 (4.45mm) screws on the bottom of the camera.
      • 2 (2.95mm) screws on the left side of the camera.
  4. There will be 2 (5.39mm) screws. Remove the screws in order to remove the lanyard. There will be 2 (5.39mm) screws. Remove the screws in order to remove the lanyard. There will be 2 (5.39mm) screws. Remove the screws in order to remove the lanyard.
    • There will be 2 (5.39mm) screws. Remove the screws in order to remove the lanyard.
  5. Remove the rear camera casing. Remove the front casing.
    • Remove the rear camera casing.
    • Remove the front casing.
  6. Spedizione gratuita per tutti gli ordini superiori a 100,00 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  7. Remove the top panel screw (1x 4.37mm). Remove the top panel screw (1x 4.37mm).
    • Remove the top panel screw (1x 4.37mm).
  8. Remove the top panel. Remove the top panel.
    • Remove the top panel.
  9. Remove the back panel screws (1x 3.33mm, and  1x 3.40mm). Remove the back panel screws (1x 3.33mm, and  1x 3.40mm).
    • Remove the back panel screws (1x 3.33mm, and 1x 3.40mm).
  10. Separate the inner casing  from the tripod mount. Separate the inner casing  from the tripod mount. Separate the inner casing  from the tripod mount.
    • Separate the inner casing from the tripod mount.
  11. Gently pull the  orange tab out of the  circuit board. Gently pull the  orange tab out of the  circuit board. Gently pull the  orange tab out of the  circuit board.
    • Gently pull the orange tab out of the circuit board.
  12. Carefully flip the LCD panel to expose the central circuit board. Carefully flip the LCD panel to expose the central circuit board.
    • Carefully flip the LCD panel to expose the central circuit board.
  13. Remove the (1x 3.33mm) screw from the menu button panel .
    • Remove the (1x 3.33mm) screw from the menu button panel .
  14. Pull the second orange tab from the circuit board and remove the buttons. Pull the second orange tab from the circuit board and remove the buttons.
    • Pull the second orange tab from the circuit board and remove the buttons.
Conclusione
Michael
Membro da: 24/06/2010
63 Reputazione
2 Guide realizzate
Cal Poly, Team 2-8, Johann Summer 2010 Membro di Cal Poly, Team 2-8, Johann Summer 2010
CPSU-JOHANN-R10S2G8
5 Membri
8 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,203
