Salta al contenuto principale
Kodak EasyShare LS743 Capacitor Replacement
Cosa ti serve
  1. Kodak EasyShare LS743 Capacitor Replacement, Battery: passo 1, immagine 1 di 1
    • Using your fingernail, open the battery cover.
  2. Kodak EasyShare LS743 Capacitor Replacement: passo 2, immagine 1 di 1
    • Slide the orange latch sideways to eject the battery.
    • Remove the battery from the battery slot.
  3. Kodak EasyShare LS743 Capacitor Replacement, Kodak EasyShare LS743 Camera Case Disassembly: passo 3, immagine 1 di 3 Kodak EasyShare LS743 Capacitor Replacement, Kodak EasyShare LS743 Camera Case Disassembly: passo 3, immagine 2 di 3 Kodak EasyShare LS743 Capacitor Replacement, Kodak EasyShare LS743 Camera Case Disassembly: passo 3, immagine 3 di 3
    • Using a Phillips #00 screwdriver, remove two 5.39 mm screws next to the battery slot.
    • Remove the metal piece holding down the lanyard, then remove the lanyard.
  4. Kodak EasyShare LS743 Capacitor Replacement: passo 4, immagine 1 di 3 Kodak EasyShare LS743 Capacitor Replacement: passo 4, immagine 2 di 3 Kodak EasyShare LS743 Capacitor Replacement: passo 4, immagine 3 di 3
    • Using a Phillips #00 screwdriver, remove seven screws located on the outside case of the camera.
    • One 6.25 mm screw is located on the top right corner, right to the "OK" button.
    • Four 4.45 mm screws are on the bottom of the camera.
    • Two 2.95 mm screws are on the left side of the camera, above the USB port.
  5. Kodak EasyShare LS743 Capacitor Replacement: passo 5, immagine 1 di 2 Kodak EasyShare LS743 Capacitor Replacement: passo 5, immagine 2 di 2
    • Carefully remove the rear camera casing.
    • Carefully remove the front camera casing.
  6. Kodak EasyShare LS743 Capacitor Replacement, Capacitor: passo 6, immagine 1 di 3 Kodak EasyShare LS743 Capacitor Replacement, Capacitor: passo 6, immagine 2 di 3 Kodak EasyShare LS743 Capacitor Replacement, Capacitor: passo 6, immagine 3 di 3
    • The capacitor can store electricity even when the camera is off! Do not touch it until you have safely discharged it.
    • Connect the two capacitor wires briefly with a pair of metal tweezers to discharge the capacitor. You may see a small spark.
    • Remove eight screws using a Phillips #00 screwdriver.
    • Two (4.31 mm) screws are in the front of the camera.
    • Two (3.30 mm) screws are located in the bottom of the camera.
    • This causes the tripod mount on the bottom to become loose.
    • Four (3 x 3.33 mm and 1 x 4.34 mm) screws are in the back of the camera.
  7. Kodak EasyShare LS743 Capacitor Replacement: passo 7, immagine 1 di 1
    • Remove the tripod mount from the bottom of the camera and set it aside.
  8. Kodak EasyShare LS743 Capacitor Replacement: passo 8, immagine 1 di 1
    • Pull the black latch outward slightly to release the orange flex cable.
    • Carefully disconnect the orange flex cable.
  9. Kodak EasyShare LS743 Capacitor Replacement: passo 9, immagine 1 di 1
    • Soldering irons pose a burn risk if handled improperly.
    • Desolder the red and black wire and remove them.
  10. Kodak EasyShare LS743 Capacitor Replacement: passo 10, immagine 1 di 2 Kodak EasyShare LS743 Capacitor Replacement: passo 10, immagine 2 di 2
    • Hold the camera firmly and gently remove the capacitor (attached by adhesive) by wiggling it loose.
    • Desolder the pink and black wire and remove both of them.
Conclusione
Cal Poly, Team 2-8, Johann Summer 2010 Membro di Cal Poly, Team 2-8, Johann Summer 2010
CPSU-JOHANN-R10S2G8
5 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,255
