Salta al contenuto principale
Kodak EasyShare LS743 Battery Door Replacement
Cosa ti serve
  1. Kodak EasyShare LS743 Battery Door Replacement, Battery: passo 1, immagine 1 di 1
    • Using your fingernail, open the battery cover.
  2. Kodak EasyShare LS743 Battery Door Replacement: passo 2, immagine 1 di 1
    • Slide the orange latch sideways to eject the battery.
    • Remove the battery from the battery slot.
  3. Kodak EasyShare LS743 Battery Door Replacement, Kodak EasyShare LS743 Camera Case Disassembly: passo 3, immagine 1 di 3 Kodak EasyShare LS743 Battery Door Replacement, Kodak EasyShare LS743 Camera Case Disassembly: passo 3, immagine 2 di 3 Kodak EasyShare LS743 Battery Door Replacement, Kodak EasyShare LS743 Camera Case Disassembly: passo 3, immagine 3 di 3
    • Using a Phillips #00 screwdriver, remove two 5.39 mm screws next to the battery slot.
    • Remove the metal piece holding down the lanyard, then remove the lanyard.
  4. Kodak EasyShare LS743 Battery Door Replacement: passo 4, immagine 1 di 3 Kodak EasyShare LS743 Battery Door Replacement: passo 4, immagine 2 di 3 Kodak EasyShare LS743 Battery Door Replacement: passo 4, immagine 3 di 3
    • Using a Phillips #00 screwdriver, remove seven screws located on the outside case of the camera.
    • One 6.25 mm screw is located on the top right corner, right to the "OK" button.
    • Four 4.45 mm screws are on the bottom of the camera.
    • Two 2.95 mm screws are on the left side of the camera, above the USB port.
  5. Kodak EasyShare LS743 Battery Door Replacement: passo 5, immagine 1 di 2 Kodak EasyShare LS743 Battery Door Replacement: passo 5, immagine 2 di 2
    • Carefully remove the rear camera casing.
    • Carefully remove the front camera casing.
  6. Kodak EasyShare LS743 Battery Door Replacement, Battery Door: passo 6, immagine 1 di 2 Kodak EasyShare LS743 Battery Door Replacement, Battery Door: passo 6, immagine 2 di 2
    • Remove loose battery door.
Conclusione
Odessa
Membro da: 06/24/10
55 Reputazione
2 Guide realizzate
Cal Poly, Team 2-8, Johann Summer 2010 Membro di Cal Poly, Team 2-8, Johann Summer 2010
CPSU-JOHANN-R10S2G8
5 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,736
