Salta al contenuto principale
Kodak EasyShare C913 Memory Card Replacement
  1. Kodak EasyShare C913 Memory Card Replacement, Memory Card: passo 1, immagine 1 di 3 Kodak EasyShare C913 Memory Card Replacement, Memory Card: passo 1, immagine 2 di 3 Kodak EasyShare C913 Memory Card Replacement, Memory Card: passo 1, immagine 3 di 3
    • Position the camera with the bottom facing up.
    • With your finger, slide the battery cover in the direction of open arrow.
    • The battery cover will spring open so be careful to lift it up gently.
  2. Kodak EasyShare C913 Memory Card Replacement: passo 2, immagine 1 di 2 Kodak EasyShare C913 Memory Card Replacement: passo 2, immagine 2 di 2
    • Push down on the memory card and it will spring up.
    • Grip and pull up the memory card to remove it.
Conclusione
Cal Poly, Team 7-51, Amido Fall 2010 Membro di Cal Poly, Team 7-51, Amido Fall 2010
CPSU-AMIDO-F10S7G51
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 14
Tutti i Tempi: 2,590
