Salta al contenuto principale
Kodak EasyShare C913 Capacitor Replacement
Cosa ti serve
  1. Kodak EasyShare C913 Capacitor Replacement, Batteries: passo 1, immagine 1 di 3 Kodak EasyShare C913 Capacitor Replacement, Batteries: passo 1, immagine 2 di 3 Kodak EasyShare C913 Capacitor Replacement, Batteries: passo 1, immagine 3 di 3
    • Position the camera with the bottom facing up.
    • Slide the battery cover in the direction of the arrow with your finger gently.
    • Remove the batteries
  2. Kodak EasyShare C913 Capacitor Replacement, Back Case: passo 2, immagine 1 di 3 Kodak EasyShare C913 Capacitor Replacement, Back Case: passo 2, immagine 2 di 3 Kodak EasyShare C913 Capacitor Replacement, Back Case: passo 2, immagine 3 di 3
    • Remove the seven 4.5mm screws with a Phillips #00 screwdriver.
    • 2 on the left
    • 2 on the right
    • 3 on the bottom
  3. Kodak EasyShare C913 Capacitor Replacement: passo 3, immagine 1 di 3 Kodak EasyShare C913 Capacitor Replacement: passo 3, immagine 2 di 3 Kodak EasyShare C913 Capacitor Replacement: passo 3, immagine 3 di 3
    • Firmly grasp the back of the camera and pull the away the casing.
  4. Kodak EasyShare C913 Capacitor Replacement, Front Case: passo 4, immagine 1 di 3 Kodak EasyShare C913 Capacitor Replacement, Front Case: passo 4, immagine 2 di 3 Kodak EasyShare C913 Capacitor Replacement, Front Case: passo 4, immagine 3 di 3
    • Keep the battery door open
    • Firmly grasp the front casing and pull away from the camera.
  5. Kodak EasyShare C913 Capacitor Replacement, Capacitor: passo 5, immagine 1 di 2 Kodak EasyShare C913 Capacitor Replacement, Capacitor: passo 5, immagine 2 di 2
    • Orient the camera with the lens facing you.
    • Use a Phillips #00 screwdriver to remove the one 2.2mm screw on the plastic bridge.
    • Lift the plastic bridge off and place it to the side.
  6. Kodak EasyShare C913 Capacitor Replacement: passo 6, immagine 1 di 1
    • Do not touch the capacitor contact points for any reason. This will result in a severe shock.
  7. Kodak EasyShare C913 Capacitor Replacement: passo 7, immagine 1 di 3 Kodak EasyShare C913 Capacitor Replacement: passo 7, immagine 2 di 3 Kodak EasyShare C913 Capacitor Replacement: passo 7, immagine 3 di 3
    • Grasp the capacitor, carefully remove it from its holder, and place it off to the side.
  8. Kodak EasyShare C913 Capacitor Replacement: passo 8, immagine 1 di 1
    • De-solder the connections at the base of the capacitor
Conclusione
Alan Galarza
Membro da: 10/03/10
72 Reputazione
3 Guide realizzate
Cal Poly, Team 7-51, Amido Fall 2010 Membro di Cal Poly, Team 7-51, Amido Fall 2010
CPSU-AMIDO-F10S7G51
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 3,995
