Salta al contenuto principale
Kodak EasyShare C713 Lens Replacement
Cosa ti serve
  1. Kodak EasyShare C713 Lens Replacement, Batteries: passo 1, immagine 1 di 1
    • Use your finger tip to slide battery cover door away from the center of the camera.
    • The battery door should spring open.
    • If this does not happen, gently open the door lifting from the outer bottom side of the camera.
    I tried to buy battery
    Rudranil Mandal - Replica
  2. Kodak EasyShare C713 Lens Replacement: passo 2, immagine 1 di 1
    • Remove the old batteries.
  3. Kodak EasyShare C713 Lens Replacement, Outer Case: passo 3, immagine 1 di 3 Kodak EasyShare C713 Lens Replacement, Outer Case: passo 3, immagine 2 di 3 Kodak EasyShare C713 Lens Replacement, Outer Case: passo 3, immagine 3 di 3
    • Remove the seven screws from the outer case with a Phillips #00.
    • All screws are 4.45mm.
    • There are 2 screws on the port side.
    • There are 2 screws on starboard side.
    • There are 3 screws on the bottom.
  4. Kodak EasyShare C713 Lens Replacement: passo 4, immagine 1 di 3 Kodak EasyShare C713 Lens Replacement: passo 4, immagine 2 di 3 Kodak EasyShare C713 Lens Replacement: passo 4, immagine 3 di 3
    • Make sure the battery cap is "up".
    • Pull the outer case off with your hands.
  5. Kodak EasyShare C713 Lens Replacement, LCD: passo 5, immagine 1 di 1
    • The LCD screen is hinged at the bottom.
    • Put your thumb in the upper right corner of the LCD screen.
    • Pull the LCD screen out of its outer case with your thumb.
  6. Kodak EasyShare C713 Lens Replacement: passo 6, immagine 1 di 1
    • Remove the screw underneath LCD screen with the Phillips #00. The screw measures 4.1mm in length.
  7. Kodak EasyShare C713 Lens Replacement: passo 7, immagine 1 di 2 Kodak EasyShare C713 Lens Replacement: passo 7, immagine 2 di 2
    • Desolder the two points.
    • One on the port side.
    • One on the bottom.
  8. Kodak EasyShare C713 Lens Replacement: passo 8, immagine 1 di 1
    • After desoldering the LCD casing, just use your fingers to carefully remove it.
  9. Kodak EasyShare C713 Lens Replacement: passo 9, immagine 1 di 1
    • Flip up the black tab on the bottom of the LCD screen with a fingertip.
  10. Kodak EasyShare C713 Lens Replacement: passo 10, immagine 1 di 1
    • Remove the LCD ribbon cable from inside the black tab.
  11. Kodak EasyShare C713 Lens Replacement, Lens: passo 11, immagine 1 di 1
    • Using a fingertip, flip the black tab near the top of the camera.
    • Remove the ribbon connector from inside the black tab.
  12. Kodak EasyShare C713 Lens Replacement: passo 12, immagine 1 di 1
    • Remove the remaining eight 4.1mm screws on the back with the Phillips #00 screwdriver.
  13. Kodak EasyShare C713 Lens Replacement: passo 13, immagine 1 di 1
    • Desolder the upper points.
    • There is a series of solder points in a rectangular area in the upper middle of the camera.
    • There is a large solder point in the upper right.
  14. Kodak EasyShare C713 Lens Replacement: passo 14, immagine 1 di 1
    • Turn the camera over.
    • Remove the silver 2.2mm battery cap screw.
  15. Kodak EasyShare C713 Lens Replacement: passo 15, immagine 1 di 2 Kodak EasyShare C713 Lens Replacement: passo 15, immagine 2 di 2
    • Pry the capacitor out of its holder on the bottom of the camera with your fingers.
  16. Kodak EasyShare C713 Lens Replacement: passo 16, immagine 1 di 3 Kodak EasyShare C713 Lens Replacement: passo 16, immagine 2 di 3 Kodak EasyShare C713 Lens Replacement: passo 16, immagine 3 di 3
    • Remove the lens assembly with your fingers.
    • You may need to wiggle it back and forth until it comes loose.
    • Do not touch the marked areas. This will cause the camera to take blurry pictures.
Conclusione
Cal Poly, Team 26-19, Regan Spring 2010 Membro di Cal Poly, Team 26-19, Regan Spring 2010
CPSU-REGAN-S10S26G19
4 Membri
14 Guide realizzate
Un commento
why didn't you mention to discharge the capacitor, its stored charge is pretty high & dangerous
richard - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 6,941
