Salta al contenuto principale
Kodak EasyShare C713 LCD Replacement
Cosa ti serve
  1. Kodak EasyShare C713 LCD Replacement, Batteries: passo 1, immagine 1 di 1
    • Use your finger tip to slide battery cover door away from the center of the camera.
    • The battery door should spring open.
    • If this does not happen, gently open the door lifting from the outer bottom side of the camera.
    I tried to buy battery
    Rudranil Mandal - Replica
  2. Kodak EasyShare C713 LCD Replacement: passo 2, immagine 1 di 1
    • Remove the old batteries.
  3. Kodak EasyShare C713 LCD Replacement, Outer Case: passo 3, immagine 1 di 3 Kodak EasyShare C713 LCD Replacement, Outer Case: passo 3, immagine 2 di 3 Kodak EasyShare C713 LCD Replacement, Outer Case: passo 3, immagine 3 di 3
    • Remove the seven screws from the outer case with a Phillips #00.
    • All screws are 4.45mm.
    • There are 2 screws on the port side.
    • There are 2 screws on starboard side.
    • There are 3 screws on the bottom.
  4. Kodak EasyShare C713 LCD Replacement: passo 4, immagine 1 di 3 Kodak EasyShare C713 LCD Replacement: passo 4, immagine 2 di 3 Kodak EasyShare C713 LCD Replacement: passo 4, immagine 3 di 3
    • Make sure the battery cap is "up".
    • Pull the outer case off with your hands.
  5. Kodak EasyShare C713 LCD Replacement, LCD: passo 5, immagine 1 di 1
    • The LCD screen is hinged at the bottom.
    • Put your thumb in the upper right corner of the LCD screen.
    • Pull the LCD screen out of its outer case with your thumb.
  6. Kodak EasyShare C713 LCD Replacement: passo 6, immagine 1 di 1
    • Remove the screw underneath LCD screen with the Phillips #00. The screw measures 4.1mm in length.
  7. Kodak EasyShare C713 LCD Replacement: passo 7, immagine 1 di 2 Kodak EasyShare C713 LCD Replacement: passo 7, immagine 2 di 2
    • Desolder the two points.
    • One on the port side.
    • One on the bottom.
  8. Kodak EasyShare C713 LCD Replacement: passo 8, immagine 1 di 1
    • After desoldering the LCD casing, just use your fingers to carefully remove it.
  9. Kodak EasyShare C713 LCD Replacement: passo 9, immagine 1 di 1
    • Flip up the black tab on the bottom of the LCD screen with a fingertip.
  10. Kodak EasyShare C713 LCD Replacement: passo 10, immagine 1 di 1
    • Remove the LCD ribbon cable from inside the black tab.
Conclusione
Altre 6 persone hanno completato questa guida.
Cal Poly, Team 26-19, Regan Spring 2010 Membro di Cal Poly, Team 26-19, Regan Spring 2010
CPSU-REGAN-S10S26G19
4 Membri
14 Guide realizzate
2 Commenti
Thank you... i fixed my old camera lcd.
anthoxman - Replica
hvor kan jeg kjøpe LCD skjermen til dette kamerat, og hva koster et sånn LCD-skjerm
fancy tassen - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 5,254
