Salta al contenuto principale
Kodak EasyShare C713 Capacitor Replacement
Cosa ti serve
  1. Kodak EasyShare C713 Capacitor Replacement, Batteries: passo 1, immagine 1 di 1
    • Use your finger tip to slide battery cover door away from the center of the camera.
    • The battery door should spring open.
    • If this does not happen, gently open the door lifting from the outer bottom side of the camera.
  2. Kodak EasyShare C713 Capacitor Replacement: passo 2, immagine 1 di 1
    • Remove the old batteries.
  3. Kodak EasyShare C713 Capacitor Replacement, Outer Case: passo 3, immagine 1 di 3 Kodak EasyShare C713 Capacitor Replacement, Outer Case: passo 3, immagine 2 di 3 Kodak EasyShare C713 Capacitor Replacement, Outer Case: passo 3, immagine 3 di 3
    • Remove the seven screws from the outer case with a Phillips #00.
    • All screws are 4.45mm.
    • There are 2 screws on the port side.
    • There are 2 screws on starboard side.
    • There are 3 screws on the bottom.
  4. Kodak EasyShare C713 Capacitor Replacement: passo 4, immagine 1 di 3 Kodak EasyShare C713 Capacitor Replacement: passo 4, immagine 2 di 3 Kodak EasyShare C713 Capacitor Replacement: passo 4, immagine 3 di 3
    • Make sure the battery cap is "up".
    • Pull the outer case off with your hands.
  5. Kodak EasyShare C713 Capacitor Replacement, Capacitor: passo 5, immagine 1 di 2 Kodak EasyShare C713 Capacitor Replacement, Capacitor: passo 5, immagine 2 di 2
    • To avoid an electric shock, do not to touch capacitor.
    • The capacitor is located underneath the lens.
    • It is held in place by 4 plastic snaps; it can be easily removed by pulling outward with your fingers.
  6. Kodak EasyShare C713 Capacitor Replacement: passo 6, immagine 1 di 1
    • Desolder points connecting capacitor to circuit board.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 26-19, Regan Spring 2010 Membro di Cal Poly, Team 26-19, Regan Spring 2010
CPSU-REGAN-S10S26G19
4 Membri
14 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 22
Tutti i Tempi: 4,365
