Salta al contenuto principale
Kodak EasyShare C713 Buttons Replacement
Cosa ti serve
  1. Kodak EasyShare C713 Buttons Replacement, Batteries: passo 1, immagine 1 di 1
    • Use your finger tip to slide battery cover door away from the center of the camera.
    • The battery door should spring open.
    • If this does not happen, gently open the door lifting from the outer bottom side of the camera.
  2. Kodak EasyShare C713 Buttons Replacement: passo 2, immagine 1 di 1
    • Remove the old batteries.
  3. Kodak EasyShare C713 Buttons Replacement, Outer Case: passo 3, immagine 1 di 3 Kodak EasyShare C713 Buttons Replacement, Outer Case: passo 3, immagine 2 di 3 Kodak EasyShare C713 Buttons Replacement, Outer Case: passo 3, immagine 3 di 3
    • Remove the seven screws from the outer case with a Phillips #00.
    • All screws are 4.45mm.
    • There are 2 screws on the port side.
    • There are 2 screws on starboard side.
    • There are 3 screws on the bottom.
  4. Kodak EasyShare C713 Buttons Replacement: passo 4, immagine 1 di 3 Kodak EasyShare C713 Buttons Replacement: passo 4, immagine 2 di 3 Kodak EasyShare C713 Buttons Replacement: passo 4, immagine 3 di 3
    • Make sure the battery cap is "up".
    • Pull the outer case off with your hands.
  5. Kodak EasyShare C713 Buttons Replacement, Buttons: passo 5, immagine 1 di 1
    • Remove the necessary broken buttons.
    • They come out easily so just use your fingers.
Conclusione
Cal Poly, Team 26-19, Regan Spring 2010 Membro di Cal Poly, Team 26-19, Regan Spring 2010
CPSU-REGAN-S10S26G19
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 2,940
