Introduzione
Use this guide to remove and replace the battery door.
Cosa ti serve
Use your finger tip to slide battery cover door away from the center of the camera.
The battery door should spring open.
If this does not happen, gently open the door lifting from the outer bottom side of the camera.
Remove the seven screws from the outer case with a Phillips #00.
All screws are 4.45mm.
There are 2 screws on the port side.
There are 2 screws on starboard side.
There are 3 screws on the bottom.
Make sure the battery door is open.
Using a pair of tweezers, remove the metal rod at the junction of the battery door and the inner camera case.
I tried to buy battery
Rudranil Mandal - Replica
Please help me
