Introduzione
This guide will show you how to remove and replace the memory card.
Strumenti
Nessun attrezzo richiesto.
Parti
  1. First, access the slide door on the bottom left corner of the camera.  To open, push down and to the left. First, access the slide door on the bottom left corner of the camera.  To open, push down and to the left. First, access the slide door on the bottom left corner of the camera.  To open, push down and to the left.
    • First, access the slide door on the bottom left corner of the camera. To open, push down and to the left.
  2. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  3. The memory card slot is located just below the batteries. To insert the memory card, make sure the writing is facing the batteries, and the cut off corner is at the top right.  Put the card into the slot and push until you hear a click. You do not need to remove the batteries  to insert the memory card.
    • The memory card slot is located just below the batteries.
    • To insert the memory card, make sure the writing is facing the batteries, and the cut off corner is at the top right. Put the card into the slot and push until you hear a click.
    • You do not need to remove the batteries to insert the memory card.
  4. This is what the memory card should look like when finished.
    • This is what the memory card should look like when finished.
Conclusione
To remove, push the memory card until you feel a click. The card should pop out.
Alyssa
Membro da: 12/04/2012
69 Reputazione
4 Guide realizzate
Cal Poly, Team 6-22, Amido Spring 2012 Membro di Cal Poly, Team 6-22, Amido Spring 2012
CPSU-AMIDO-S12S6G22
4 Membri
4 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,701
