Salta al contenuto principale
Kobo Arc K107 USB Replacement
Cosa ti serve
  1. Kobo Arc K107 USB Replacement, Battery: passo 1, immagine 1 di 1
    • Peel the back cover off of the Kobo Arc by finding the lip in the cover and pulling back on it.
  2. Kobo Arc K107 USB Replacement: passo 2, immagine 1 di 1
    • Remove the screws from the midframe.
  3. Kobo Arc K107 USB Replacement: passo 3, immagine 1 di 1
    • Use a nylon spudger to pry up the battery from the device.
    • It will give some resistance as it is glued down.
    • Always use plastic or nylon prying tools around the battery. Metal tools can puncture a battery, potentially causing a fire.
  4. Kobo Arc K107 USB Replacement: passo 4, immagine 1 di 1
    • Unplug the battery connector from the rest of the tablet.
    • Remove the battery from the tablet.
  5. Kobo Arc K107 USB Replacement, USB: passo 5, immagine 1 di 1
    • Remove the motherboard from the outer case.
  6. Kobo Arc K107 USB Replacement: passo 6, immagine 1 di 1
    • Detach the USB cable from the motherboard.
    • Remove the USB port from the tablet.
Conclusione
Ray Starpoli
Membro da: 10/28/21
169 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 282
