Salta al contenuto principale
Kobo Arc K107 Screen Replacement
Cosa ti serve
  1. Kobo Arc K107 Screen Replacement, Battery: passo 1, immagine 1 di 1
    • Peel the back cover off of the Kobo Arc by finding the lip in the cover and pulling back on it.
  2. Kobo Arc K107 Screen Replacement: passo 2, immagine 1 di 1
    • Remove the screws from the midframe.
  3. Kobo Arc K107 Screen Replacement: passo 3, immagine 1 di 1
    • Use a nylon spudger to pry up the battery from the device.
    • It will give some resistance as it is glued down.
    • Always use plastic or nylon prying tools around the battery. Metal tools can puncture a battery, potentially causing a fire.
  4. Kobo Arc K107 Screen Replacement: passo 4, immagine 1 di 1
    • Unplug the battery connector from the rest of the tablet.
    • Remove the battery from the tablet.
  5. Kobo Arc K107 Screen Replacement, Speaker: passo 5, immagine 1 di 2 Kobo Arc K107 Screen Replacement, Speaker: passo 5, immagine 2 di 2
    • Remove the screws that are attached to the grey plastic layer.
    • Remove the gray plastic layer.
  6. Kobo Arc K107 Screen Replacement: passo 6, immagine 1 di 1
    • Disconnect the speakers from the tablet.
  7. Kobo Arc K107 Screen Replacement, Screen: passo 7, immagine 1 di 2 Kobo Arc K107 Screen Replacement, Screen: passo 7, immagine 2 di 2
    • Wedge a nylon spudger between the screen and the tablet.
    • Slide the spudger around the edges of the screen and remove it from the device.
Conclusione
Stephen Pehl
Membro da: 10/28/21
303 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 329
