Introduzione
If the motor head hits up and down when kneading heavy dough, the lock no longer engages. This can indicate a defective lock, but the height adjustment of the motor head is more often responsible for this.
Cosa ti serve
Test 1: Unlock the motor head and swivel it up. Does the pawl move into the motor head housing when the locking lever is actuated?
The pawl retracts -> mechanism OK, continue with test 2
The pawl does not retract -> mechanism is defective, repair options after opening the housing is not described in these instructions.
Test 2: Check the position of the locking lever with the motor head lowered:
-> Lever engaged correctly. The motor head is locked and cannot be lifted. Then the head shouldn't hit while kneading ;-)
-> Lever not properly engaged. The motorhead can be lifted without operating the lever -> continue with step 2
Next, check the correct adjustment of the motor head according to the instructions https://de.ifixit.com/Anleitung/KitchenA ...
Make sure that the distance is as small as possible according to the instructions (5ct coin should just be touched while the machine is running and only move a few millimeters further in the bowl) If necessary, carry out adjustment according to the instructions.
If an adjustment was necessary and the head was put down, the problem with the beating motor head can already be resolved and the lock engages correctly. Repeat step 1 - test 2.
If the problem persists, go to step 3
Fold the motor head up until it clicks into place
Carefully work the rear edge of the pawl with the Dremel and remove material evenly. Material removal per pass in the area of a few hundredths of a millimeter, then check the locking again.
Repeat until the lock engages correctly and without play.
Function test will show successful repair
Altre 2 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
100%
oldturkey03 ci sta aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
2 Commenti
Bei mir ist das Gegenteil der Fall. Der Schlitz für die Verriegelung im Gehäuse ist ausgeschlagen.
Thanks for the tips. I needed to adjust the head screw and file the clip. I used a file on the clip instead of a dremmel. The clip is quite soft metal which probaly causes the problem in the first place, but makes it easy to file.
