Salta al contenuto principale
KitchenAid KSM150PSER Circuit Board Replacement
Cosa ti serve
  1. KitchenAid KSM150PSER Circuit Board Replacement, Circuit Board: passo 1, immagine 1 di 2 KitchenAid KSM150PSER Circuit Board Replacement, Circuit Board: passo 1, immagine 2 di 2
    • Using a Phillips #2 screwdriver, remove the 10mm screw on the back cover by rotating it counterclockwise.
    • The back cover is now free. Remove it by pulling it back and up.
    • Ensure that the mixer is disconnected from any electrical source prior to removing the back cover.
  2. KitchenAid KSM150PSER Circuit Board Replacement: passo 2, immagine 1 di 2 KitchenAid KSM150PSER Circuit Board Replacement: passo 2, immagine 2 di 2
    • Using a Phillips #1 screwdriver, remove the 9.5mm screw above the circuit board by rotating it counterclockwise.
    • If you can't see the screw, try pulling the seal down past the wires to make the screw more accessible.
  3. KitchenAid KSM150PSER Circuit Board Replacement: passo 3, immagine 1 di 2 KitchenAid KSM150PSER Circuit Board Replacement: passo 3, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using pliers or tweezers, remove the connectors of the four wires attached to the circuit board.
  4. KitchenAid KSM150PSER Circuit Board Replacement: passo 4, immagine 1 di 1
    • Grab the wires and tilt the edge of the board up to lift the circuit board up and out.
Conclusione
Altre 4 persone hanno completato questa guida.
Luke Leonard
Membro da: 01/24/18
571 Reputazione
2 Guide realizzate
Cal Poly, Team S2-G5, Livingston Winter 2018 Membro di Cal Poly, Team S2-G5, Livingston Winter 2018
CPSU-LIVINGSTON-W18S2G5
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 47
Tutti i Tempi: 5,387
