Salta al contenuto principale
KitchenAid KSM150PSER Carbon Brushes Replacement
Cosa ti serve
  1. KitchenAid KSM150PSER Carbon Brushes Replacement, Carbon Brushes: passo 1, immagine 1 di 2 KitchenAid KSM150PSER Carbon Brushes Replacement, Carbon Brushes: passo 1, immagine 2 di 2
    • Using a flat head screwdriver, unscrew the brush cap on each side of the mixer by turning them counter clockwise.
    • Remove brush cap by pulling it toward you.
    • The brushes are held in by springs and will fly out if removed too fast.
  2. KitchenAid KSM150PSER Carbon Brushes Replacement: passo 2, immagine 1 di 1
    • Remove brush by pulling it toward you.
    • One corner of the brush is flattened. You can check which way the brush is oriented by shining a flashlight inside the hole.
Conclusione
Altre 6 persone hanno completato questa guida.
Hayley Young
Membro da: 12/03/16
211 Reputazione
1 Guida realizzata
Cal Poly, Team S2-G5, Livingston Winter 2018 Membro di Cal Poly, Team S2-G5, Livingston Winter 2018
CPSU-LIVINGSTON-W18S2G5
4 Membri
10 Guide realizzate
Un commento
I’ve been procrastinating on trying to fix my KA mixer on my own…today I did it. The directions were pretty clear and the only thing wrong was that when I had previously cleaned my mixer, I put the carbon brushes in the wrong way. Once I shined a flashlight into the hole I could see where the notched corner went.
Amber Reimer - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 30
Ultimi 30 Giorni: 142
Tutti i Tempi: 15,110
