Salta al contenuto principale
KitchenAid KSB5CR Power Cable Replacement
Cosa ti serve
  1. KitchenAid KSB5CR Power Cable Replacement, Removing the Back Panel Part 1: passo 1, immagine 1 di 3 KitchenAid KSB5CR Power Cable Replacement, Removing the Back Panel Part 1: passo 1, immagine 2 di 3 KitchenAid KSB5CR Power Cable Replacement, Removing the Back Panel Part 1: passo 1, immagine 3 di 3
    • Remove the glass container and place the blender upside down on a solid surface.
    • Remove the four rubber feet using the needle nose pliers.
    • Remove the four #7.5 Phillips 25mm screws that were located underneath the rubber feet using the Phillips #2 screwdriver.
  2. KitchenAid KSB5CR Power Cable Replacement, Removing the Back Panel Part 2: passo 2, immagine 1 di 1
    • Lift the back panel up, sliding it along the power cord.
  3. KitchenAid KSB5CR Power Cable Replacement, Freeing the Power Cable: passo 3, immagine 1 di 1
    • Lift up on the power cable to pop it out of its holder.
  4. KitchenAid KSB5CR Power Cable Replacement, Detaching the White and Black Wires: passo 4, immagine 1 di 2 KitchenAid KSB5CR Power Cable Replacement, Detaching the White and Black Wires: passo 4, immagine 2 di 2
    • Be gentle with the knife or you will break the circuit board.
    • Slide the knife into the metal loop holding the insulation before the white copper wire, and wiggle it back and forth until it loosens.
    • Pull the wire out from the metal loop that you loosened.
    • Repeat this process with the black copper wire.
  5. KitchenAid KSB5CR Power Cable Replacement, Detatching the Green Wire: passo 5, immagine 1 di 2 KitchenAid KSB5CR Power Cable Replacement, Detatching the Green Wire: passo 5, immagine 2 di 2
    • Using the Phillips #2 screwdriver, remove the #8 Phillips 6mm screw to which the green wire is attached.
Conclusione
Cal Poly, Team 12-5, Forte Fall 2014 Membro di Cal Poly, Team 12-5, Forte Fall 2014
CPSU-FORTE-F14S12G5
5 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 12
Tutti i Tempi: 662
