Salta al contenuto principale
KitchenAid KSB5CR Fan Replacement
Cosa ti serve
  1. KitchenAid KSB5CR Fan Replacement, Removing the Back Panel Part 1: passo 1, immagine 1 di 3 KitchenAid KSB5CR Fan Replacement, Removing the Back Panel Part 1: passo 1, immagine 2 di 3 KitchenAid KSB5CR Fan Replacement, Removing the Back Panel Part 1: passo 1, immagine 3 di 3
    • Remove the glass container and place the blender upside down on a solid surface.
    • Remove the four rubber feet using the needle nose pliers.
    • Remove the four #7.5 Phillips 25mm screws that were located underneath the rubber feet using the Phillips #2 screwdriver.
  2. KitchenAid KSB5CR Fan Replacement, Removing the Back Panel Part 2: passo 2, immagine 1 di 1
    • Lift the back panel up, sliding it along the power cord.
  3. KitchenAid KSB5CR Fan Replacement, Removing the Fan Chassis Part 1: passo 3, immagine 1 di 3 KitchenAid KSB5CR Fan Replacement, Removing the Fan Chassis Part 1: passo 3, immagine 2 di 3 KitchenAid KSB5CR Fan Replacement, Removing the Fan Chassis Part 1: passo 3, immagine 3 di 3
    • Remove the two #5 Phillips 95 mm machine screws using the Phillips #2 screwdriver.
    • Remove the rubber O-ring by lifting it up.
    • Remove the ribbon cable from the chassis by lifting it up.
  4. KitchenAid KSB5CR Fan Replacement, Removing the Fan Chassis Part 2: passo 4, immagine 1 di 3 KitchenAid KSB5CR Fan Replacement, Removing the Fan Chassis Part 2: passo 4, immagine 2 di 3 KitchenAid KSB5CR Fan Replacement, Removing the Fan Chassis Part 2: passo 4, immagine 3 di 3
    • Unhook the white wire that is looped around the peg by pulling it out of the clip.
    • Repeat this process with the red wire on the other side of the chassis.
    • Remove the end cap using the 8" needle nose pliers.
    • Pull up the fan chassis.
  5. KitchenAid KSB5CR Fan Replacement, Removing the Fan: passo 5, immagine 1 di 1
    • Remove the fan by lifting it upwards.
    • This step is difficult and requires force. Use of both hands is recommended.
Conclusione
Cal Poly, Team 12-5, Forte Fall 2014 Membro di Cal Poly, Team 12-5, Forte Fall 2014
CPSU-FORTE-F14S12G5
5 Membri
6 Guide realizzate
3 Commenti
Hi,
Do you know if it is possible to convert Kitchenaid Artisan stand mixer to 240v, has anyone looked inside or know if i should change something.
Ancient warrior - Replica
Does raplacing the fan mean that the fan itself (when broken) can be ordered? So just the white plastic round part. If so, could someone please give me a reference number? Would be highly appreciated.
Hugo, the Netherlands.
Hugo - Replica
my blender turn on all the numbers light at the same time and is not working at all. do you know what the problem could be?
patricia - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 2,235
