Salta al contenuto principale
KitchenAid KHM512ER Beater Rings Replacement
Cosa ti serve
  1. KitchenAid KHM512ER Beater Rings Replacement, Beater Rings: passo 1, immagine 1 di 2 KitchenAid KHM512ER Beater Rings Replacement, Beater Rings: passo 1, immagine 2 di 2
    • Insert the back of a plastic opening tool into one of the beater holes
    • Apply force to pull the circular plastic part off.
    • If necessary, use the other side of the plastic opening tool to pry the circular plastic part off.
  2. KitchenAid KHM512ER Beater Rings Replacement: passo 2, immagine 1 di 2 KitchenAid KHM512ER Beater Rings Replacement: passo 2, immagine 2 di 2
    • Use a Phillips #2 screwdriver to remove the two 20mm screws holding the bottom plastic piece in place.
    • Remove the bottom plastic piece using a plastic opening tool.
  3. KitchenAid KHM512ER Beater Rings Replacement: passo 3, immagine 1 di 2 KitchenAid KHM512ER Beater Rings Replacement: passo 3, immagine 2 di 2
    • Using a Phillips 2 screwdriver, remove the three 20.0mm screws holding the motor assembly in place.
    • Use your hands to remove the motor assembly.
  4. KitchenAid KHM512ER Beater Rings Replacement: passo 4, immagine 1 di 2 KitchenAid KHM512ER Beater Rings Replacement: passo 4, immagine 2 di 2
    • Firmly grip the motor in your hand. Using pliers, pull the connectors off the motors.
    • Some force may be required. Be careful not to cut yourself on any electrical components.
  5. KitchenAid KHM512ER Beater Rings Replacement: passo 5, immagine 1 di 2 KitchenAid KHM512ER Beater Rings Replacement: passo 5, immagine 2 di 2
    • Lie the motor down flat on a table.
    • Using a pair of tweezers, remove the ring from the plastic knob.
Conclusione
Altre 3 persone hanno completato questa guida.
Brad Daniels
Membro da: 02/10/16
585 Reputazione
3 Guide realizzate
USF Tampa, Team 2-3, Sullivan Spring 2016 Membro di USF Tampa, Team 2-3, Sullivan Spring 2016
USFT-SULLIVAN-S16S2G3
3 Membri
4 Guide realizzate
3 Commenti
Anyone know of a site that sells replacement beater gears?
joescherzo - Replica
Nice set by step process but where does one get the rings?
M Stevens - Replica
try Sears parts.com
Yvette Tower - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 46
Tutti i Tempi: 5,903
