Salta al contenuto principale
KitchenAid Classic Mixer K45SSWH Beater Head Adjustment
Cosa ti serve
  1. KitchenAid Classic Mixer K45SSWH Beater Head Adjustment, Adjust the height: passo 1, immagine 1 di 2 KitchenAid Classic Mixer K45SSWH Beater Head Adjustment, Adjust the height: passo 1, immagine 2 di 2
    • Lift the mixer arm and locate the large screw where the base meets the arm.
    • Using a flathead screwdriver, turn the screw counter-clockwise to raise the beater head or turn it clockwise to lower the beater head.
    • The beater head should pass only about 1/16th of an inch above the base of the bowl. One good way to get the height right is to place a dime in the bowl and adjust the height until the beater head barely brushes the dime as it passes.
    Thank you! Problem solved!!!
    mirdel - Replica
    Bravo,ich wusste bisher nicht, wozu die Schraube gut ist!
    Arbeitsgruppe Dialog - Replica
    Der Trick mit der Münze ist gut, eine 5ct Münze sollte bei laufender Maschine nur leicht touchiert werden und ein paar Millimeter in der Schüssel weiter bewegt werden.
    KaiVi - Replica
Conclusione
Once your beater head is at the appropriate height, you're good to go.
Altre 4 persone hanno completato questa guida.
Cal Poly, Team 14-28, Maness Fall 2014 Membro di Cal Poly, Team 14-28, Maness Fall 2014
CPSU-MANESS-F14S14G28
4 Membri
22 Guide realizzate
2 Commenti
Very helpful. Thank you for the info, it worked!!
suz - Replica
I have a K5ss by Hobbart. Do you know how to adjust the bowl/beater clearance.?This machine does not have the screw that adjusts the clearance like the K45ss does. The manual tells how to turn a screw to adjust the clearance on a k45ss, but says to consult an authorized dealer for the k5ss. I called around and nobody in my area works on mixers. Is this something I can do myself? Any help would be appreciated.
Aide L. - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 27
Ultimi 30 Giorni: 144
Tutti i Tempi: 13,343
