Salta al contenuto principale
Introduzione
This guide clearly describes how to disassemble a kitchen scale.
Parti
Nessuna parte specificata.
  1. Remove the battery cover and batteries. Remove the battery cover and batteries.
    • Remove the battery cover and batteries.
  2. Peel off the information sticker.
    • Peel off the information sticker.
  3. Unscrew the ten screws (countersunk cross head 1,5 mm; 8 mm). Unscrew the ten screws (countersunk cross head 1,5 mm; 8 mm). Unscrew the ten screws (countersunk cross head 1,5 mm; 8 mm).
    • Unscrew the ten screws (countersunk cross head 1,5 mm; 8 mm).
  4. Remove the black back cover.
    • Remove the black back cover.
  5. Remove the tape which holds the electrical wires in place. Remove the tape which holds the electrical wires in place.
    • Remove the tape which holds the electrical wires in place.
  6. Push down the click fingers and slide out the feet. Push down the click fingers and slide out the feet. Push down the click fingers and slide out the feet.
    • Push down the click fingers and slide out the feet.
  7. Remove the backlight from the screen.
    • Remove the backlight from the screen.
  8. Unscrew the 5 screws from the PCB and screen (round cross head 1,5 mm; 6 mm). Unscrew the 5 screws from the PCB and screen (round cross head 1,5 mm; 6 mm).
    • Unscrew the 5 screws from the PCB and screen (round cross head 1,5 mm; 6 mm).
  9. Lift out the PCB and screen. Lift out the PCB and screen.
    • Lift out the PCB and screen.
  10. Pry out the PCBs which include the touch sensors (2). Pry out the PCBs which include the touch sensors (2).
    • Pry out the PCBs which include the touch sensors (2).
  11. Lift out the complete electronic circuit and remove the screen and connector. Lift out the complete electronic circuit and remove the screen and connector.
    • Lift out the complete electronic circuit and remove the screen and connector.
  12. Pry off the metal cover from the top of the kitchen scale. Remove the glass screen cover. Remove the glass screen cover.
    • Pry off the metal cover from the top of the kitchen scale.
    • Remove the glass screen cover.
Conclusione
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 30
Tutti i Tempi: 513
