Salta al contenuto principale
Kitchen Gourmet Waffle Maker Release Latch Spring Replacement
Cosa ti serve
  1. Kitchen Gourmet Waffle Maker Release Latch Spring Replacement, Release Latch Spring: passo 1, immagine 1 di 1
    • Unplug the waffle maker.
  2. Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: passo 2, immagine 1 di 3 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: passo 2, immagine 2 di 3 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: passo 2, immagine 3 di 3
    • Open the waffle maker.
    • Make sure the waffle maker's surface is not hot.
  3. Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: passo 3, immagine 1 di 3 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: passo 3, immagine 2 di 3 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: passo 3, immagine 3 di 3
    • Spray the interior of the waffle maker with cleaning solution.
    • Clean and wipe down the surface.
  4. Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: passo 4, immagine 1 di 2 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: passo 4, immagine 2 di 2
    • Use a Phillips #1 screwdriver to remove the four screws that secure the plastic handle cover.
    • Spin in counterclockwise direction to loosen.
  5. Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: passo 5, immagine 1 di 3 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: passo 5, immagine 2 di 3 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: passo 5, immagine 3 di 3
    • Carefully pull back the plastic cover, and gently remove the release latch.
  6. Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: passo 6, immagine 1 di 2 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: passo 6, immagine 2 di 2
    • Remove the spring from the latch.
  7. Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: passo 7, immagine 1 di 3 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: passo 7, immagine 2 di 3 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: passo 7, immagine 3 di 3
    • Carefully replace with the new spring.
    • Pliers are recommended but removal with hands is fine.
    • Be careful not to bend the spring when pushing into the plastic handle.
  8. Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: passo 8, immagine 1 di 3 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: passo 8, immagine 2 di 3 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: passo 8, immagine 3 di 3
    • Orient the release latch in the correct direction, and line up the spring.
  9. Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: passo 9, immagine 1 di 3 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: passo 9, immagine 2 di 3 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: passo 9, immagine 3 di 3
    • Hold the latch in place.
    • Line up the screw holes on the plastic cover to the waffle maker lid.
  10. Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: passo 10, immagine 1 di 2 Kitchen Gourmet Waffle Maker Release Latch Spring Replacement: passo 10, immagine 2 di 2
    • Screw in all four screws tightly.
    • Spin in clockwise direction to tighten.
    • Screw in opposing screws first to keep them in place.
Conclusione
Fatima Ruiz Ruiz
Membro da: 02/01/24
193 Reputazione
1 Guida realizzata
UC Davis, Team 3-4, Andersen Winter 2024 Membro di UC Davis, Team 3-4, Andersen Winter 2024
UCD-ANDERSEN-W24S3G4
3 Membri
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 13
Tutti i Tempi: 88
