Salta al contenuto principale
Kirby G5 Vacuum Belt Replacement
Cosa ti serve
  1. Kirby G5 Vacuum Belt Replacement, Vacuum Belt: passo 1, immagine 1 di 1
    • Place the vacuum at an angle most comfortable and easy to access with the bottom facing upwards.
  2. Kirby G5 Vacuum Belt Replacement: passo 2, immagine 1 di 2 Kirby G5 Vacuum Belt Replacement: passo 2, immagine 2 di 2
    • Remove the three screws holding the base plate to the body of the vacuum using a flat head screwdriver.
    • Place the plate to the side.
  3. Kirby G5 Vacuum Belt Replacement: passo 3, immagine 1 di 1
    • Simply slide the roller out of the vacuum.
    • The belt is attached to the roller on either side.
  4. Kirby G5 Vacuum Belt Replacement: passo 4, immagine 1 di 2 Kirby G5 Vacuum Belt Replacement: passo 4, immagine 2 di 2
    • Slide the vacuum belt out from beneath the wheel holding it in place.
  5. Kirby G5 Vacuum Belt Replacement: passo 5, immagine 1 di 1
    • Insert your new belt and pop the roller back into place.
  6. Kirby G5 Vacuum Belt Replacement: passo 6, immagine 1 di 2 Kirby G5 Vacuum Belt Replacement: passo 6, immagine 2 di 2
    • Secure the plate once again until it clicks into the made grooves.
    • Secure the three screws until tightened.
Conclusione
Make sure to test the vacuum and securely tighten all screws. With that, you’re good to go!
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 58
Tutti i Tempi: 1,118
