Salta al contenuto principale
Kinivo ZX100 Mini Portable Speaker Replacement
Cosa ti serve
  1. Kinivo ZX100 Mini Portable Speaker Replacement, Disassembling Kinivo ZX100 Mini Portable Speaker: passo 1, immagine 1 di 1
    • Open the circular portion at the top of the speaker by twisting it until it reaches the maximum possible height.
    • Make sure it is twisted fully, as this will allow access to four screws to be removed in the next step.
  2. Kinivo ZX100 Mini Portable Speaker Replacement: passo 2, immagine 1 di 2 Kinivo ZX100 Mini Portable Speaker Replacement: passo 2, immagine 2 di 2
    • Remove the four 12 mm Phillips screws from the enclosure.
  3. Kinivo ZX100 Mini Portable Speaker Replacement: passo 3, immagine 1 di 2 Kinivo ZX100 Mini Portable Speaker Replacement: passo 3, immagine 2 di 2
    • Separate the resonator portion from the base of device to reveal the middle separator of the enclosure. The enclosure will now be in two pieces.
    • Hold the resonator portion of the enclosure gently aside to make sure there is no tension on the black and red wires coming from the bottom portion of the device.
    • Excessive force may disconnect the black and red speaker wires from the circuitry in the bottom portion of the device.
  4. Kinivo ZX100 Mini Portable Speaker Replacement: passo 4, immagine 1 di 1
    • Separate the very bottom portion of the enclosure (marked in red) by pulling vertically on the red portion of the enclosure (marked in orange).
    • Gently set the very bottom portion and the resonator section aside once they have both been separated.
    • Remove the circuit board with your hands by lifting and sliding the board away from the LED indicator.
  5. Kinivo ZX100 Mini Portable Speaker Replacement, Speaker: passo 5, immagine 1 di 1
    • Desolder both wired connections.
    • Once the solder has melted, the wires should be easily pulled off the circuit board.
    • Be sure to connect the black wire to SPK- and the red wire to SPK+ when soldering the wires back onto the circuit board.
Conclusione
Test the speaker once you’ve reassembled it. Sound should now play properly on your Kinivo ZX100 Mini Portable Speaker.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 5
Tutti i Tempi: 446
