Salta al contenuto principale
Kindle Voyage Wifi Antenna Replacement
Cosa ti serve
  1. Kindle Voyage Wifi Antenna Replacement, Back Panel: passo 1, immagine 1 di 2 Kindle Voyage Wifi Antenna Replacement, Back Panel: passo 1, immagine 2 di 2
    • Insert a plastic opening tool between the plastic panel shown on the device.
    • Use the tool to pry the plastic away from the device.
    • There will be adhesive holding this piece of plastic to the device. You may have to pull pretty hard to get it separated.
  2. Kindle Voyage Wifi Antenna Replacement: passo 2, immagine 1 di 1
    • Use an aluminum driver attached with a Phillips head size #00 to remove the four 3mm screws shown in the picture. For reassembly, note that the top two and bottom two screws are different sizes.
  3. Kindle Voyage Wifi Antenna Replacement: passo 3, immagine 1 di 3 Kindle Voyage Wifi Antenna Replacement: passo 3, immagine 2 di 3 Kindle Voyage Wifi Antenna Replacement: passo 3, immagine 3 di 3
    • Once the screws are removed, the back panel can slide off the device.
  4. Kindle Voyage Wifi Antenna Replacement: passo 4, immagine 1 di 2 Kindle Voyage Wifi Antenna Replacement: passo 4, immagine 2 di 2
    • Remove the magnetic component with the magnetic head of the aluminum driver.
  5. Kindle Voyage Wifi Antenna Replacement, Wifi Antenna: passo 5, immagine 1 di 2 Kindle Voyage Wifi Antenna Replacement, Wifi Antenna: passo 5, immagine 2 di 2
    • Use an aluminum driver with Phillips head #00 to remove the four 3 mm screws shown in the picture.
    • Use the same driver to remove the two 2.5 mm screws.
  6. Kindle Voyage Wifi Antenna Replacement: passo 6, immagine 1 di 3 Kindle Voyage Wifi Antenna Replacement: passo 6, immagine 2 di 3 Kindle Voyage Wifi Antenna Replacement: passo 6, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using the tweezers, undo the attached clip.
    • Remove the three 3 mm screws holding down the rest of the antenna with an aluminum driver and the Phillips #00 head.
    • You should now be able to simply take the WiFi bar off of the device.
Conclusione
Sean Yap
Membro da: 01/22/15
1.346 Reputazione
6 Guide realizzate
Cal Poly, Team 19-12, Maness Winter 2015 Membro di Cal Poly, Team 19-12, Maness Winter 2015
CPSU-MANESS-W15S19G12
5 Membri
10 Guide realizzate
Un commento
Re Kindle Voyage Wifi Antenna Replacement guide: I cannot find the WiFi antenna bar on your website to purchase a replacement. Do you sell it?
carol cooper - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 16
Tutti i Tempi: 1,974
