Salta al contenuto principale
Kindle Voyage Battery Replacement
Cosa ti serve
  1. Kindle Voyage Battery Replacement, Back Panel: passo 1, immagine 1 di 2 Kindle Voyage Battery Replacement, Back Panel: passo 1, immagine 2 di 2
    • Insert a plastic opening tool between the plastic panel shown on the device.
    • Use the tool to pry the plastic away from the device.
    • There will be adhesive holding this piece of plastic to the device. You may have to pull pretty hard to get it separated.
  2. Kindle Voyage Battery Replacement: passo 2, immagine 1 di 1
    • Use an aluminum driver attached with a Phillips head size #00 to remove the four 3mm screws shown in the picture. For reassembly, note that the top two and bottom two screws are different sizes.
  3. Kindle Voyage Battery Replacement: passo 3, immagine 1 di 3 Kindle Voyage Battery Replacement: passo 3, immagine 2 di 3 Kindle Voyage Battery Replacement: passo 3, immagine 3 di 3
    • Once the screws are removed, the back panel can slide off the device.
  4. Kindle Voyage Battery Replacement: passo 4, immagine 1 di 2 Kindle Voyage Battery Replacement: passo 4, immagine 2 di 2
    • Remove the magnetic component with the magnetic head of the aluminum driver.
  5. Kindle Voyage Battery Replacement, Battery: passo 5, immagine 1 di 2 Kindle Voyage Battery Replacement, Battery: passo 5, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Plastic Cards
    $2.99
    Compra
    • Use a plastic card to pry the battery away from the device.
    • Gently un-clip the battery plug from the device and remove the battery.
Conclusione
Altre 27 persone hanno completato questa guida.
Sean Yap
Membro da: 01/22/15
1.253 Reputazione
6 Guide realizzate
Cal Poly, Team 19-12, Maness Winter 2015 Membro di Cal Poly, Team 19-12, Maness Winter 2015
CPSU-MANESS-W15S19G12
5 Membri
8 Guide realizzate
15 Commenti
Where can I buy a replacement buttery for my kindle voyage?
hegi88 - Replica
Where to find a replacement battery for kindle voyage 3G please if any one knows
Himadri Endow - Replica
Bump. Cannot seem to procure a new battery for the Kindle Voyage. Nice to know how to replace the old one; just need something to replace it WITH! Thanks for any hints on finding one. Battery model number is: MC-305070, 3.8V 1320mAh/5.01Wh, P/N 58-000056
larryg - Replica
Any advance on where one can find a replacement battery for the Kindle Journal?
Charles WRIGHT - Replica
Still looking for a source for this battery.
Neil Hall - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 99
Ultimi 30 Giorni: 496
Tutti i Tempi: 27,101
