Salta al contenuto principale
Kindle Touch Battery Replacement
Cosa ti serve
  1. Kindle Touch Battery Replacement, Back Cover: passo 1, immagine 1 di 3 Kindle Touch Battery Replacement, Back Cover: passo 1, immagine 2 di 3 Kindle Touch Battery Replacement, Back Cover: passo 1, immagine 3 di 3
    • Use the plastic opening tool to undo the ten plastic clips around the back panel of the Kindle.
    Wear work gloves as the tool can easily slip and stab you in the hand.
    BRUCE - Replica
    The clips aren't all the same; the side clips are slide-locks rather than press-locks.
    Use the Opening Tool to unclip the clips along the bottom edge. This will allow the lid to slide towards the top, releasing the side clips and allowing the lid to be lifted off.
    When reassembling, slide the lid upwards while pressing the sides to re-engage the side clips, then press the bottom edge to lock it into place.
    jimf - Replica
  2. Kindle Touch Battery Replacement: passo 2, immagine 1 di 2 Kindle Touch Battery Replacement: passo 2, immagine 2 di 2
    • Gently lift the bottom and slide the panel off.
    There are four tabs on each side.The two nearest the top are open at the top, hence they slide out (back towards the power connector end.
    This is important in the reassembly stage:
    1. Align the back cover about 0.75 cm away from the top
    2. Hold the top half of the cover flat against the unit, and flex the cover away from the case a little at the bottom
    3. Slide the top and the first two clips parallel to the case
    4. snap the remaining bottom clips in place
    John Haywood - Replica
  3. Kindle Touch Battery Replacement, Battery: passo 3, immagine 1 di 3 Kindle Touch Battery Replacement, Battery: passo 3, immagine 2 di 3 Kindle Touch Battery Replacement, Battery: passo 3, immagine 3 di 3
    • Use a Phillips #00 screwdriver to remove the five screws.
  4. Kindle Touch Battery Replacement: passo 4, immagine 1 di 3 Kindle Touch Battery Replacement: passo 4, immagine 2 di 3 Kindle Touch Battery Replacement: passo 4, immagine 3 di 3
    • Using the flat end of your spudger, gently pry the battery up and remove it.
Conclusione
Altre 18 persone hanno completato questa guida.
Adam Yerly
Membro da: 01/20/15
1.933 Reputazione
7 Guide realizzate
USF Tampa, Team 19-5, Blackwell Winter 2015 Membro di USF Tampa, Team 19-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S19G5
3 Membri
8 Guide realizzate
Un commento
Where can I buy a new battery?
Carla Grobler (Ubbink) - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 24
Ultimi 30 Giorni: 126
Tutti i Tempi: 10,121
