Salta al contenuto principale
Kindle Touch 3G Card Housing Replacement
Cosa ti serve
Panoramica Video
  1. Kindle Touch 3G Card Housing Replacement, Back Cover: passo 1, immagine 1 di 3 Kindle Touch 3G Card Housing Replacement, Back Cover: passo 1, immagine 2 di 3 Kindle Touch 3G Card Housing Replacement, Back Cover: passo 1, immagine 3 di 3
    • Use the plastic opening tool to undo the ten plastic clips around the back panel of the Kindle.
  2. Kindle Touch 3G Card Housing Replacement: passo 2, immagine 1 di 2 Kindle Touch 3G Card Housing Replacement: passo 2, immagine 2 di 2
    • Gently lift the bottom and slide the panel off.
  3. Kindle Touch 3G Card Housing Replacement, Battery: passo 3, immagine 1 di 3 Kindle Touch 3G Card Housing Replacement, Battery: passo 3, immagine 2 di 3 Kindle Touch 3G Card Housing Replacement, Battery: passo 3, immagine 3 di 3
    • Use a Phillips #00 screwdriver to remove the five screws.
  4. Kindle Touch 3G Card Housing Replacement: passo 4, immagine 1 di 3 Kindle Touch 3G Card Housing Replacement: passo 4, immagine 2 di 3 Kindle Touch 3G Card Housing Replacement: passo 4, immagine 3 di 3
    • Using the flat end of your spudger, gently pry the battery up and remove it.
  5. Kindle Touch 3G Card Housing Replacement, Remove the 3G Board: passo 5, immagine 1 di 3 Kindle Touch 3G Card Housing Replacement, Remove the 3G Board: passo 5, immagine 2 di 3 Kindle Touch 3G Card Housing Replacement, Remove the 3G Board: passo 5, immagine 3 di 3
    • Remove the indicated four 2 mm screws with a Phillips #00 screwdriver. (Units with the 3G assembly have Phillips #000 screws.)
    • Next, gently lift the 3G assembly with a Spudger or your fingers.
    • This Kindle Touch is the WiFi only model and comes with a plastic placeholder instead of the 3G assembly.
    • Disconnect the antenna lead by carefully prying it off the 3G board with a plastic tool.
Conclusione
Altre 3 persone hanno completato questa guida.
Adam Yerly
Membro da: 01/20/15
1.933 Reputazione
7 Guide realizzate
USF Tampa, Team 19-5, Blackwell Winter 2015 Membro di USF Tampa, Team 19-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S19G5
3 Membri
8 Guide realizzate
2 Commenti
Hey, thanks for your guide!
I, however, have one question, maybe I misunderstood - is it possible to add a 3G module to a kindle touch that didn't have one installed by default?
Would it work?
Curious_Guy_Threepwood - Replica
You would need to add more than just a 3G module - there’s a slot for a SIM-card tray and special Amazon SIM that are missing from non-3G Kindle Touches. I don’t know if there would be any software changes that would need making.
Darren John de Lima -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 18
Tutti i Tempi: 2,021
